Thought I'd add that when I lock the car (with the key or door), the lights do turn off. They just can't turn off while driving.
Printable View
Hey Don,
I'm after some advice regarding your tweak for instrument cluster lighting.
I am finding that with window tinting on a overcast Brisbane day, the instrument cluster often dims to a point where it's almost impossible to read. I have the head lights set to come on "Early" which reduces the duration of unreadability.
I have applied your recommended values for daylight or "X" and found the situation to be a bit better. However, it looks like I would have to tweak the value of X5 further so the cluster stays lit up until the headlights come on, and leave the "Y" values as factory to maintain the dark-out reminder to turn on headlights if I ever have it in the off position.
If my understanding is correct from reading your documentation, I need to decrease the decimal value of X5 from 100 to something even lower.
Alternatively, I could half the decimal value of X2 and X3, and this should keep the clusters lit up for a bit longer until the dark-out kicks in.
Is this right?
Also sanity check: X curve = parking lights off, Y curve = parking lights on?
Any help you can offer here would be greatly appreciated :)
Answered my own question. Halving the X5 value in Don's spreadsheet has done the trick, so it would appear. Time will tell.
Also Don, not sure if you are aware, but I think the photo transistor is actually on the side with the Tacho, not in the middle under the MFD as per your literature. I have attached a photo, it's the round thing next to the high beam indicator.
It is the only area that responded to my focused spot light.
http://www.vwwatercooled.com.au/foru...b24eed34-1.jpg
Agentthumb: Sorry that I couldn't get to you sooner, but I'm glad that you sorted-out your problem.
Had I responded sooner, I would have suggested that you download my macro spread-sheet and try different lighting curves HERE.
The X5 value is certainly the fixing-point for the greatest daylight illumination, but you might find that the cluster illumination needs a tweak at lower ambient light levels. It's a bit of a compromise really between increasing the illumination on the cluster and not having the other phototransistor controlled items too bright. You could of course also tweak these other curves, if you have the interest.
But if you are happy with my tweak curve, then there's nothing more to do (mercifully)
PS Thanks for the location of the phototransistor - I think you are correct - that looks like the spot
Some stats
My Discover Pro FW 192 - WLAN enabled 1.5 years ago https://www.drive.net/l/4359571/
My Discover Pro updated to 388 - WLAN doesnt show in Menu, but show as inactive in Media Source...
Columbus SW 390 (same as Discover Pro SW 388) - WLAN activated successfully https://www.drive.net/l/8898320/
any ideas why dont work with 388 DP?))))
I have 0388 myself and it works.
However, you should look at these things in a seperate way:
- WLAN Hotspot
- WLAN Media Source.
WLAN Media source is only available when you have a DLNA server running on your WLAN network. Otherwise, there would be no source.
You might need to re-enable WLAN again after updating. Updating sometimes resets some settings to what VW wants them to be.
Including a reset? ;)
