VCDS (VAG-COM) codes and programmable options for Golf Mk7
Quote:
Originally Posted by
HPSOV
Hi All,
I bought the Ross Tech cable and have enabled a few of the tweaks listed on this site. I would like to enable the Traffic Information, however both of the posts linked in the tweak reference thread refer to changing the default value of 0 to 1024. But my default value isn't 0, it is a 5 digit number, something like 16652. So I am hesitant to change it to 1024 as it doesn't match what other have seen, I wonder if this is a MY16 change as my car has the newer infotainment system.
When I am on the Nav screen there is a TP at the top, but when I press the traffic button there are no reports and TMC has a line through it. I assume this means traffic isn't enabled.
Am I safe to change the 16652 to 1024 and see what happens?
Yes. My MY15 had 16652 as well. Worst case you can just change it back.
Electric Parking Brake (EPB)- Open/close procedure for Pad Replacement
Just a heads-up that Ross-Tech have published a process for closing/opening the callipers on EPB versions of the mk7. Handy if you are contemplating the removal/replacement of the rear pads.
The link to the Ross-tech wiki-page is HERE
PS: I was asked to try out the procedure on my RoW vehicle before publication and I can vouch that it works perfectly on our Aussie cars!
VCDS Tweak: Pace-Car indicators for dual LED tail lights
As a factory setting, VW program their vehicles that are fitted with dual LED rear lamps so that the outer and inner LED indicators flash in unison with one another (i.e. they pulse on/off together). I recently found an interesting German video (copy below) showing Dual LED rear lamps that flashed asynchronously when the turn signal was operated. Clever folk those Germans!!
https://www.youtube.com/watch?featur...;v=H7kbrRfBFGs
Galvanised into action by this intriguing (at least to me) lighting effect, I managed to develop a set of Leuchte programming instructions that would mimic the operation of the indicator lights in the video. Thought that it might be of interest to forum members that have dual LED fittings on their rear lights (like the Golf R).
For fellow "Leuchte geeks" (I proudly acknowledge being one!) reading this, the tweak uses the AB Alpha pair, which has the lowest priority in the Leuchte-set and it is based on the (less familiar) Blinken link/rechts Dunkelphase setting. But, the interesting part of the tweak is that instead of the usual practice of linking this setting with Dimmwert=0 and Dimming Direction=minimum, the tweak uses Dimmwert=100 and Dimming Direction=maximum (which is applied to the Heckdeckel channel on the AB alpha-pair). Fortuitously, both these settings are already set-up as default for the Dimming channels on the left/right side inner rear lights. This means that only Leuchte channel (4) on each lamp needs to be changed - making this a very simple tweak to implement! Programmed in this fashion, the LED indicator that has the Dunkelphase setting pulses counter to its neighbouring LED indicator which continues to use the factory programmed Hellphase setting. Here endeth the "geek" part of the tweak instructions!
Because my 103TSI mk7 has incandescent rear lamps, I have not been able to test this tweak on my vehicle (albeit, I suspect that a similar effect can be implemented by tweaking Leuchte23SL HLC10 and Leuchte24SL HRA65 on cars with incandescent fittings- something for a later experiment, perhaps). However, a forum colleague on VWVortex has confirmed that the tweak was successfully implemented on his vehicle (thanks Chillout). Also, I've been told by more knowledgeable folk (thanks again Chillout) that an appropriate description for the lighting effect is "pace car indicator" (I had never seen a pace-car, let alone knew how its lighting operated) - hence the heading to this post.
Lastly, I make no judgement regarding the compliance (or otherwise) of the "pace car indicator" with the Australian Design Rules ADR here in Oz, or whatever local legislation applies in other countries. Those wishing to implement the tweak will need to reach their own conclusions regarding this matter.
VCDS Tweak Instructions: "Pace - Car" Indicators for dual rear LED light fittings
- Select 09 - Central Electr control module
- Select Security Access - 16 from the "Open Controller" screen
- Enter the magic number 31347 and return to the "Open Controller" screen
- Select Adaptation - 10 from the "Open Controller" screen
- From the pull-down button check that the default settings for the adaptation channels shown in the table below are as indicated in the Old setting column
- Change the two Leuchte channels depicted in the table below to the values in the New Settings column.
Suggestion: use the new "search" facility on the latest RT software to find the channels listed below as follows:- Enter Leuchte16BLK into the search box to find the Left Hand LED channels
- Enter Leuchte17TFL into the search box to find the Right Hand LED channels
http://www.vwwatercooled.com.au/foru...MCnIMpng-2.jpg
Notes:
- Only one Leuchte channel for each of the left, right side lamps needs to be altered (i.e. (4)- Leuchte). I've included the remaining channels in the Leuchte sub-set as an aid to check the suitability of this tweak
- Do not implement this tweak if:
- The vehicle does not have dual LED indicators on each side
- the default settings on the vehicle are not as shown in the "old setting" column
