Results 1 to 10 of 30
Thread: Permanent 12V supply to Power Socket
Threaded View
DV52 Permanent 12V supply to Power... 13-08-2014, 02:57 PM
giveway Does this do the same for the... 13-08-2014, 03:28 PM
DV52 giveaway: Yes. Fuse position... 13-08-2014, 05:31 PM
flight dv52 - I can't help wondering... 14-08-2014, 04:50 PM
DV52 flight: I do like the way... 14-08-2014, 05:42 PM
flight Sadly, I think you may be... 14-08-2014, 08:18 PM
donweather Both my Tiggy and Occy have... 13-08-2014, 04:07 PM
booba Love your work guys, will be... 13-08-2014, 06:09 PM
wai Just remember that the... 13-08-2014, 11:09 PM
DV52 Wai: you make a very good... 14-08-2014, 10:37 AM
brad Skoda Octavia has permanently... 14-08-2014, 07:37 PM
Guest001 Does it come with a lighter... 14-08-2014, 07:48 PM
brad Yep genuine lighter. Czech... 14-08-2014, 08:27 PM
wai So did my Caddy until I... 14-08-2014, 10:43 PM
DV52 wai: I've never seen what... 14-08-2014, 11:14 PM
brad I didn't say it was right. ... 15-08-2014, 11:43 AM
donweather Lighting Ciggys? None of my... 14-08-2014, 12:21 PM
DV52 Donweather: Hi Don? No,... 14-08-2014, 12:45 PM
wai It's not whether you light a... 14-08-2014, 01:16 PM
Idle I think the 12V outlets were... 14-08-2014, 02:49 PM
b c This. If you left a battery... 14-08-2014, 05:32 PM
The_Hawk My 2010 T5GP has a cigarette... 15-08-2014, 05:22 PM
DV52 Hawk: I normally think of the... 15-08-2014, 05:59 PM
Matty4 I know this is a bit of a... 16-07-2017, 09:44 AM
Guest001 Buy an addafuse and fit in an... 16-07-2017, 11:33 AM
    Have you ever wanted the cigarette lighter in the centre console to be permanently connected to the 12 Volt battery (instead of the current arrangement where the 12V supply is switched through the ignition key)? Well, I found-out from a post on Golfmk7.com that it's a real easy thing to do!
    The process goes something like this (grateful acknowledgement to Westy23 for the original information):
    Access the fuse board behind the Glove-box (you should know how to access the fuse-board in case a fuse needs to be replaced)
    1. Open the Glove-box and empty any contents
    2. Gently but firmly push-in and lift the two tabs shown on the diagram below and hold the Glove-box so as to allow it to SLOWLY drop. As the Glove-box lowers, take note of the small "slider-bar" which is attached to the left side of the Glove-box. Notice how the bar slides out of its receptacle (which looks like a wheel with a longitudinal square hole).
    Permanent 12V supply to Power Socket-fcs0yos-png
    Relocate Cigarette lighter fuse
    1. Locate the fuse in position #40 on the fuse-board. The correct fuse is on the lower right-hand corner of the fuse-board, It is yellow in colour and it has "20" embossed in white lettering on the top (meaning that it is a 20Amp fuse). See the picture below
    2. Remove the fuse and note that there are three contacts for this fuse position (which has the number "40" embossed on the black fuse board). The fuse that you just removed was connected to the lower and middle contacts.
    3. Replace the Yellow fuse but make sure that it is inserted so that it connects the upper and middle contacts on position 40
    Permanent 12V supply to Power Socket-2asiw2g-png
    Re-install the Glove-box
    1. Gently lift the Glove-box and make sure that the slider bar on the left side fits back into the square hole in its receptacle (see picture below)
    2. Carefully but forcibly push the Glove-box home against the resistance of the two catches
    3. Put-back all the Glove-box junk that absolutely has to be there!
    4. Fully close the Glove-box door
    Permanent 12V supply to Power Socket-rh5pvvf-jpg
