Results 1 to 10 of 11
Thread: VW Golf GTi 7.5 - missing front undertray
    Feb 2008
    NSW
    Quick query for the GTi owners.
    Check out the attached photo.
    I noticed a wiring harness hanging down and visible under the engine the other day. It looks like it is from the oil sensor under the sump. It all looked very dodgy and likely to be easily damaged. I was able to poke it back up and out of the way as shown in the photo but reckon it will drop again before too long. I then began to wonder if there should be a plastic undertray there that might have been removed and not replaced at an oil service. Would someone on here with a 2018 GTi kindly have a look under the front of their car and see if the sump is exposed and visible, and if the oil sensor wiring is tucked up and out of the way ? Cheers
    Attached Thumbnails Attached Thumbnails VW Golf GTi 7.5 - missing front undertray-img_5810-jpg
    Jul 2018
    Camden Sydney
    looks the same as my GTI
    May 2007
    Nothing unusual there mate...
    Pacific Paradise QLD
    Seems VW are cost cutting as the Tiguans are similar and have a piddly little undertray and a poster on here had a connector ripped out in a similar position to yours. I have bought a full undertray for mine as in the pics.
    In actual fact VCW list a full undertray but dont seem to fit them as one is listed but as not fitted in my cars spec sheet
    Also they have taken to not fully painting inside the engine bay and the underside of the bonnet
    Attached Thumbnails Attached Thumbnails VW Golf GTi 7.5 - missing front undertray-20190911_193036[1]-jpg   VW Golf GTi 7.5 - missing front undertray-20190911_115125[1]-jpg
    Hillbilly in the replacement undertray are those access spots for the oil filter/drain plug etc?
    Yes Had car serviced last week without problems or comment . Cost $156 from Aliexpress
    My Lexus had the same thing - fantastic idea. Wish my SQ5 had it, you have to remove about 300x Torx bolts to get the undertray off to do an oil change.
    May 2007
    My Alltrack has a full size underbody tray (similar to your picture Hillbilly - minus the 3 access ports); as per the brochure "Engine and transmission underbody protection"
    Quote Originally Posted by ope126 View Post
    Yeah my 2011 Passat had one as well I reckon they just cutting costs and doing the minimum required
