Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Remote key stopped working
    Canberra
    The second battery was probably almost out of charge before you started using it, and using it consumed what little charge was left. As Idle says, it is easier/more convenient to replace them before they go flat.
    I've read of VWs with keyless entry needing new batteries after only 12 - 18 months. My Octavia & T5 batteries seem to last over 5 years (but neither gets used every day).
    Sep 2012
    Mine is keyless and they lasted just short of 2 years. Similar to yourself, my Yeti's were at 5 years and still going strong when I sold it.
    Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
    Apr 2017
    belgrave victoria
    Same for me rooboy
    I replaced my battery in the key some 3 months ago
    Not a very long life i suppose keyless entry and starting place a extra drain on it
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
    Canberra
    I've just checked and replaced the batteries in my remotes:
    Golf R (keyless) batteries had 20% charge 25 months after being built
    Octavia & Transporter batteries all had 60% charge after more than 5 years.
    Feb 2008
    NSW
    To check battery push the lock or unlock button of the remote while engine running. If battery getting low you will get a message in MFD to the effect of “check remote battery”. This on a 2018 model with keyless.
    May 2017
    Tasmania
    My Golf R key battery went flat after just short of two years. Pretty easy to change, batteries available from supermarket. No recoding or anything required
    2022 Tiguan R Reflex Silver
