Results 1 to 5 of 5
Thread: Problem to get my retrofitted fog lights to work properly on my Golf MK7 - 2016
    Feb 2018
    Stockholm
    Hi everyone,
    Have some problem to get my retrofit fog lights to work properly on my European Golf 7 2016, i have used mlewando guide (see the link below) exactly as he describes,
    i used the same harness (see link below) but i used aftermarket fog lights. and i also renew the light switch.
    Connected the harness from the fog lights til BCM B/45 & B/5 & and to ground.
    my car already has the Blue/green cabel from the light switch pin 5 to BCM A/29
    and i have code it as mlewando written.
    Here is the problem.
    My fog light are always on when i have the low-beam on, I cant switch them off
    The only way to switch them off is to set the light switch to parking lighs only. or disconnect the ground cable.
    I have tried 3 diffrent light switches from cars with working fog lights, both Euro och Chinese light switch.
    Dont know what to do next.
    Do i have to code something else?
    Part number on my BCM : 5Q0 937 084 CL
    I preciate all the tips and help i can get.
    regards
    Johan
    Link to harness :
    VW Golf 7 - Fog Light Wiring Harness - Retrofit -
    Link to guide:
    Quick writeup how to retrofit Fog lights - GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum
    Light bulbs coding:
    [09], {log in} -> [Adaptation channels]
    (1)-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer (6 - LED Modul for LEDs)
    (2)-Leuchte12NL LB45-Lampendefektbitposition 12,38
    (3)-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22
    (4)-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links
    (5)-Leuchte12NL LB45-Lichtfunktion B 12,Abbiegelicht links
    (6)-Leuchte12NL LB45-Dimmwert AB 12,100 (127 for LED)
    (1)-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer (6 - LED Modul for LEDs)
    (2)-Leuchte13NL RB5-Lampendefektbitposition 13,42
    (3)-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23
    (4)-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts
    (5)-Leuchte13NL RB5-Lichtfunktion B 13,Abbiegelicht rechts
    (6)-Leuchte13NL RB5-Dimmwert AB 13,100 (127 for LED)
    Feb 2018
    Stockholm
    Nevermind this thread, i have solved my problem.
    regards
    Flood22
    Pacific Paradise QLD
    Quote Originally Posted by Flood22 View Post
    regards
    Flood22
    So why not do the decent thing and tell us how you fixed it in case others have the same trouble
    Mamba Ebike to replace Tiguan
    I'll take a guess - he (she?) confused Abblendlicht rechts/links with Abbiegelicht rechts/links??
    Feb 2022
    Greece
    How you solve it ??
