Nevermind this thread, i have solved my problem.
regards
Flood22
Hi everyone,
Have some problem to get my retrofit fog lights to work properly on my European Golf 7 2016, i have used mlewando guide (see the link below) exactly as he describes,
i used the same harness (see link below) but i used aftermarket fog lights. and i also renew the light switch.
Connected the harness from the fog lights til BCM B/45 & B/5 & and to ground.
my car already has the Blue/green cabel from the light switch pin 5 to BCM A/29
and i have code it as mlewando written.
Here is the problem.
My fog light are always on when i have the low-beam on, I cant switch them off
The only way to switch them off is to set the light switch to parking lighs only. or disconnect the ground cable.
I have tried 3 diffrent light switches from cars with working fog lights, both Euro och Chinese light switch.
Dont know what to do next.
Do i have to code something else?
Part number on my BCM : 5Q0 937 084 CL
I preciate all the tips and help i can get.
regards
Johan
Link to harness :
VW Golf 7 - Fog Light Wiring Harness - Retrofit -
Link to guide:
Quick writeup how to retrofit Fog lights - GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum
Light bulbs coding:
[09], {log in} -> [Adaptation channels]
(1)-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer (6 - LED Modul for LEDs)
(2)-Leuchte12NL LB45-Lampendefektbitposition 12,38
(3)-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22
(4)-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links
(5)-Leuchte12NL LB45-Lichtfunktion B 12,Abbiegelicht links
(6)-Leuchte12NL LB45-Dimmwert AB 12,100 (127 for LED)
(1)-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer (6 - LED Modul for LEDs)
(2)-Leuchte13NL RB5-Lampendefektbitposition 13,42
(3)-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23
(4)-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts
(5)-Leuchte13NL RB5-Lichtfunktion B 13,Abbiegelicht rechts
(6)-Leuchte13NL RB5-Dimmwert AB 13,100 (127 for LED)
regards
Flood22
How you solve it ??
