Results 1 to 7 of 7
Thread: Golf Blind Spot Indicator Upgrade (Passat/Arteon/Tiguan) Style
    Dec 2017
    Just wanted to post my recent upgrade.
    After moving from a Tiguan to a Golf I was missing the blind Spot indicator that is located on the inner side of the frame.
    Very easy to see and notice when a car is in your blind spot. (atleast for me)
    The Golf has the blind spot indicator light located on the actual mirror like most other cars. (as you all know)
    After watching the upgrade retro fit instructions on youtube I decided that was exactly what I wanted.
    However as I am not good with a soldering iron and cutting tool I decided to buy the mirror case with the blind spot indicator already fitted. (just like a Tiguan)
    The case comes in silver and also glossy black. (some type of not so expensive plastic)
    All I had to do was decide if I wanted the disable to original indicator on the mirror or not.
    I decided to keep the original also.
    Here is what it looks like now
    SHaring as I believe it may be useful to others.
    Regards
    May 2020
    Canberra
    Nice work, I'll look into it.
    MY20 MK7.5 Golf GTI - Tornado Red - LP/S&SP
    MY19 AW Polo - Comfortline - DAP
    Dec 2017
    Quote Originally Posted by genebaby View Post
    I didnt think about taking photos as the original instructions had everything covered.
    However I have a few to add as mine was slightly different and easier to install.
    As the actual item is a bit tricky to find I have added the link that I used below also.
    My purchased Item is Black cover with blind spot indicator already fixed in place quite nicely.
    It also comes in a silver I believe.
    https://www.aliexpress.com/item/1005004958440535.html?spm=a2g0o.order_list.order_l ist_main.5.7f821802FYC5eu
    My amature work
    Fit the new cover making sure to feed the 2 wires through first.
    Golf Blind Spot Indicator Upgrade (Passat/Arteon/Tiguan) Style-wiring-jpg
    connect the wires as best as you can
    I just used electrical tape afterwards.
    As I said, Im not good with this sort of stuff.
    Golf Blind Spot Indicator Upgrade (Passat/Arteon/Tiguan) Style-wiring2-jpg
    Golf Blind Spot Indicator Upgrade (Passat/Arteon/Tiguan) Style-wiring1-jpg
    Thats a pretty good idea - probably something I would have done myself if I hadnt decided to sell my car.
    My wifes Audi SQ5 has a similar light in the mirror for the blindspot monitor and I agree that its more visible that just the little light in the mirror glass like the Golf has.
    2017 Ford Fiesta ST
    @ArdiL: Hi - very good solution, well done (only suggestion, is to use heat-shrink tubing as insulation over the wire-joins instead electrical tape -which tends to "un-stick" over time) !!
    Also, a colleague (@notaGolfR) used a slightly differently solution: he didn't modify the side-mirror housings but instead added a separate pair of LED indicators onto the dashboard that mimicked the mirror LEDs - see Blind Spot Monitor addition
    Don't get me wrong, I'm not suggesting that it's any better than your approach - just different
    Dec 2017
    Hi Don,
    Your right, shrink tubing is most likely the correct way to do it. However I wanted to show how NOT to do it
    I have a feeling sometime down the road I will eventually get the 'opportunlty' to redo it, the correct way.
    It is great to have multiple options to choose from when performing mods.
    I also replaced the stock indicator with a sequential type a few days ago before I performed this mod in order to get some experience taking off the cap. I also found that by lowering the mirror all the way down then using a knife to push/bend downwards the 2 clips holding the cap it would pop out easier. But as the wiring for the blind spot indicator is not visible from behind I had to remove the mirror to access it. The most delicate part of the job was removing the mirror without breaking it. (I used a suction cup to pull and a plastic tool to push from behind).
    Dec 2017
    As I ordered another set of side mirror covers (with blind spot indicators) for a family member I wanted to add a photo of the actual item as it is before installing. I believe they only come in Silver and glossy Black.
    The blind spot indicator is nicely fitted as can be seen in video.
