Originally Posted by
Paul_R
Does anyone with the 7 speeder noticing any difference in the revs as you modulate the brake pressure?
I had a Skoda 132 for a couple of days. If you didn't press the brake hard enough, when stationary, the clutches would stay engaged. As the pedal was pressed harder the revs would drop from 1000 to 800 when the clutch fully disengaged. It doesn't seem to do it on our 6 speeder, but it made me wonder how many people slip these clutches, unwittingly, at the lights.
My impression was that auto hold was partly invented to fix this issue - auto hold (or stop/ start for that matter) won't kick in unless you push the brake hard enough to disengage the clutch. If you switch off both you can slip all day...
