Results 1 to 10 of 10
Thread: Alltrack Rear Seat Release.
    May 2017
    Southern Highlands
    I have a 2019 Alltrack and the remote release near the tailgate does not really release the rear seat lock. You have to use two hands. One to pull the lever and one to push the seat forward. This seams useless to me as you may as well just use the release on the seat.
    I have had trouble with the lock not engaging but it is locking now. Previously the release would allow the seat to move about 20mm so you could let go of the handle. VW dealer says there is nothing wrong. As with previous VWs and Audis I may just pay to have it fixed. Not worth the trouble trying to get warranty out of VW Australia unless it is expensive.
    What are your thoughts. Should the seat back move forward?
    May 2017
    Tasmania
    I have a 2017 Golf R​ Wagon. Pulling the seat release makes the seat fall completely forward.
    2022 Tiguan R Reflex Silver
    May 2017
    Southern Highlands
    Mine has never done that. VW dealer mechanic says the right side one is heavier so it doesn't do that. Sounds like VW BS.
    Quote Originally Posted by syncro View Post
    Sounds like they are fobbing you off. Might be a spring or similar that is broken/missing. I dont have a VW Golf wagon, but my brother has a 2019 Skoda Octavia vRS wagon and the seats flip forward when you pull the release lever in the back.
    May 2021
    Blacktown, NSW
    Has something fallen down between the backrest and base? Maybe it's getting jammed on something?
    May 2017
    Southern Highlands
    Quote Originally Posted by wagonist View Post
    No you can tell that the lock on the top of the seat is not located properly. It is not flush with the leather like the other side.
    Sep 2012
    No problem with either releases on mine - both seats go down.
    Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
    May 2017
    Southern Highlands
    Anyone know a NSW VW dealer that actually does warranty?
    May 2017
    Southern Highlands
    Booked in for service today. Told them about the seat problem. If they do not think it is warranty they will charge $160 just to look at it. Car has done 15,000kms.
    I will never buy another new VW.
    May 2017
    Southern Highlands
    Dealer has finally repaired the problem. Backrest frame was faulty from factory.
