Results 1 to 5 of 5
Thread: Rear Interior Light
    May 2012
    Brisbane, Qld
    Rear Interior Light
    Hi, I have a 2020 GTI and have noticed that the back seat interior light remains on while driving.
    Is that normal, I fear the answer is NO. Has anyone else come across this ?
    Canberra
    It's normal when you have it switched on (even if that wasn't your intention). The switches above the rear view mirror can be a bit confusing (tricked me once). Have a fiddle with them and you should be able to switch it off.
    Quote Originally Posted by jdw View Post
    @jdw: Hi.
    Yes, as per the previous reply - it can be confusing!!
    The overhead switches work like this:
    = Switches the front interior lights ON/OFF.
    Attachment 55555 REAR = Switches the rear interior lights ON/OFF.
    = Switches the door contact switch ON/OFF.
    The interior lights are switched on automatically when the vehicle is unlocked, a door is opened, or the vehicle key is removed from the ignition lock.
    The light will go out a few seconds after all doors are closed, the vehicle is locked, or the ignition is switched on.
    & = Switches the respective reading light ON/OFF on either/both the Driver, or Passenger side
    My hunch (guess really based on your few words) is that if the rear lights remain turned-ON when the 2nd switch above is turned-OFF, there might be a problem with the switch itself -maybe?. It's a very simple single-throw, single-pole switch, so not difficult to diagnose
    May 2012
    Brisbane, Qld
    @jdw: Hi.
    thanks DV52 for the detailed response, looks like a fault, so off to the dealer we go.
    Pacific Paradise QLD
    Gert a torch and shine it on the switches One has rears on it play with that Had same trouble in my Tiguan and on looking it s easily fixed
