Quote:
Originally Posted by
jayburls
My stop/start has a mind all of its own. Some days it works regulary and other days nothing. Under the Car status auto start/stop it says power usage is too high. I've tried all different scenario's a/c off/on, radio, media off/on with no real luck. It seemed to work more when i had less than half a tank of fuel.
I mentioned it while i did the 5000km inspection service and was told that nothing showed up abnormal with battery or computer diaginosis. Strangely though since that inspection it seems to work more often on a full tank of fuel and not less than half a tank.
Go figure? But there's nothing wrong. hmmmm
Jayburls: A couple of folk have mentioned a peculiar and inexplicable behavior in the operation of their stop/start function. Well, there is a way of finding out what's actually happening with stop/start in your car. In the mk VII, all the stuff that causes stop/start to not-operate is recorded in real-time on the "Car" menu. The good thing is that these records are easily accessible by the driver using the following steps (My apology if you already know this stuff);
1. With the car running, press the "Car" button on the side of the Discover Media panel.
2 The following screen should come-up. If you get this screen, press the area of the screen circled
If the screen above does not appear when the "Car" button is pressed, then you will probably get something like the following screen
If this happens, press the "View" panel at the bottom LHS (you can just see it in the pic) and then press the "Vehicle Status" panel that I have circled (with a rectangle) . Then go to step 2 above
3. After Step 2, the following screen appears showing why stop/start is not working. What's great about this screen is that the entries update in real-time (well almost real time - it actually updates after a scanning period)!
For the sake of this post, and for the pic. in step 3, I deliberately didn't put-on my seat belt and I turned-on the air conditioner to demonstrate the stuff that can be recorded here. Notice the "little-man" symbol at the start of the last two entires -which means (I think) that these are human activated inhibitors.
The first entry "Power consumption is high" is interesting (notice, no "little-man" symbol). I think that this message is a result of the VCDS tweak that I implemented to disable stop/start (it's earlier-on in this thread). I'd would be interested if others who have tried the tweak get a similar message. If so, I'd welcome your view on why this message appears.
Incidentally, if you turn-off the Stop/Start function using the button on the center console, there is only one message on the screen in step 3 - which says something like "stop/start is deactivated".
Again, My apology if you already know this stuff
