Page 87 of 109 FirstFirst ... 3777858687888997 ... LastLast
Results 861 to 870 of 1081
Thread: Mk7 Golf TSI & TDI - Observations and Questions
  1. #861
    Jul 2012
    So this afternoon my infotainment screen refused to turn on after work. It's happened before but only for a few minutes. This time it wouldn't come on for the entire 30min drive home despite me stopping and trying various things on the way. Eventually the last of my MANY engine off and back on attempts worked.
    Googling suggests its not uncommon, and as mentioned Ive had it before myself.
    Any one else experience this? Software or hardware issue perhaps?
  2. #862
    Dec 2015
    Hey guys, got my GTI about 1-2 weeks ago and been loving it since, great new experience.
    Just a few nigglies:
    1. CarPlay apps seem to crash sometimes, specifically Apple Maps and Messages. Do you guys even use Apple Maps? I kinda prefer the inbuilt Nav system but it doesn't have Siri unfortunately.
    2. 6th gear - I've been playing around with 'manual' mode a bit, and notice if I'm travelling ar 50-60kph and knock it into 6th gear and accelerate, there's like a vibration noise, struggling noise... i know this is probably because i'm loading up the transmission/engine incorrectly but is this normal and is it doing any damage???
    Thanks!
  3. #863
    Dec 2009
    Kew, VIC
    Can't help you with Carplay — never even seen it — but the answer to the 'struggling noise' is simply Don't Do That!
    6th gear is set high for economy – if you open the throttle wide at low revs you overstress things and the engine makes 'struggling noises' simply because it's struggling.
    For your engine's (and your wallet's) sake, use fourth or fifth instead.
  4. #864
    Sep 2015
    Quote Originally Posted by wahoo View Post
    Thanks!
    During the past week or two software has been released and available at dealers to rectify many problems with MIB II, including CarPlay bugs. I wouldn't leave it until your first service to update the software either as you don't want some of the other issues to surface.
    White MY17 Golf 7R with DSG and DAP.
  5. #865
    Mar 2009
    Quote Originally Posted by VRJ View Post
    It has?
    This is stuff VW should be releasing to customers. We shouldn't need to come across this information by accident online.
    MY16 MK7 Golf GTI
    - Manual - Sunroof - Folding Mirrors - Lock/Unlock Chirp - 4x Indicator Flash - Traffic - MK7.5 LED Tail Lights with Sweeping Indicators - Dynablink Sweeping mirror LEDs - White LED's on rear rego plate -
  6. #866
    Feb 2013
    northern Perth WA
    Question Two year service, dealer recommendations, TDI 2014
    Had a dig around and couldn't find relevant info, so... Our diesel wagon is having its 2 year / 30K service in about 3 weeks. It's had normal suburban and freeway use with the odd country trip vs severe conditions as described in the book. The dealer recommends replacing pollen filter and brake fluid on top of the specified items. What's the opinion of the knowledgeable forum members? Neither? Either? Both?
  7. #867
    Sep 2011
    If my understanding is correct, pollen filter cleans the air coming into the cabin. So if you have no problems with the air coming in and have no allergies, it can be replaced when you feel like it.
    Brake fluids should be replaced every 2 years regardless of mileage as it gradually absorbs water from the atmosphere. This results in the brake fluid more likely to boil. 2 years is the general recommendation for most manufactureres and I think it's important not to skimp on safety.
  8. #868
    Nov 2015
    Adelaide, South Australia
    Dealers like to "Jab" you at service time .
    My Mk7 petrol is due for 2nd service (21,000Km) in a couple of weeks and have started a list of Don't do...
    . Do not replace pollen filter (inspected & cleaned 18K Km)
    . Do not replace wiper blades
    . Do not add injector cleaner to fuel tank (use BP Ultimate 9
    . Do not top up or supply windscreen washer fluid
    Interestingly I have also a '97 Volvo 850 that uses the same ATE brake system as our Mk4 Golf, both the independent and dealer
    Volvo service does not do a 2 year brake fluid change.
    Instead they check the moisture level in the fluid reservoir with a gadget and in 16 years of ownership fluid was only replaced recently due to new brake hoses being fitted.(I'm in dry Adelaide climate so SYD, BRIS, MEL may differ)
    Have also heard of dealers cheating by only flushing out of 1 nipple.
    That has to be a savings of about $200 which I can put towards sourcing those parts plus filters, sump plugs,brake pads from OS.
    Valvster
  9. #869
    Oct 2015
    Darwin, Northern Territory, Australia
    In your service manual are a list of items that the factory deems necessary for each specific service. Any thing over and above these are the dealer attempting to make additional profits from you at the service. These are not "MUST" be done items, just their recommendations, which in turn they charge an additional fee for. Not doing these additional items will not affect your warranty, not changing a pollen filter at the recommended intervals wont affect your warranty, only your nose.
  10. #870
    Erskineville, NSW
    Quote Originally Posted by adhock View Post
    Pollen filter is every 2 years in your service book. You're better off getting one off ebay for $20 and DIYing every 12 months as they become pretty ugly. Get the carbon impregnated jobbie.
    First brake fluid is at 3 years and every 2 years after that - again, it's in your service book.
