Anyone know if this procedure can be carried out in a mk6?Quote:
Enable Traffic Information (TMC) on Mk7 Golf - VCDS tweak
Step 1. On "Select Control Module" option click "Select"
Attachment 8318
Step 2. Select "5F-information Elect"
Attachment 8319
Step 3. Select "Adaptation"
Attachment 8320
Step 4. Using pull-down menu, select "Fee Based Traffic Information (TMC)" channel (it's about 20% down the channel list)
Step 5 Change default value "0" to ?????
Edit (30/04/2015): The magic number for Step 5 is apparently "1024".
This value was initially suggested in sucnip's post below (see #55)
And the value was confirmed in alanzidan's post below (see #48 - tweak 5.1)The remaining steps in the procedure are:
Attachment 9241
Step 5. Enter "1024" into "New Value" box and click "Do It!" tab.
Attachment 9606
Step 6. Click the "Yes" tab in the "Re-code Invalid" screen.
Step 7. When the screen in Step 5 returns, click "Add to log" to record a copy of the change report.
Step 8. Click "Go Back" (in Step 5 screen) and exit the VCDS software
Missing Adaptation channel - Fix
The channel, Fee Based Traffic Information (TMC) in step (4) appears in the drop-down list if byte 13 of 5F-information Elect. controller has a coding value of hex09. If this channel does not appear, then byte 13 may need to be changed to this vaue (thanks zloybob.)
Please note the following after the tweak has been completed:
- For TMC to work, "TP" and "RDS" need to be activated in the set-up menu for the radio
- It may take some time for the new facility to be established and for the initial set of traffic reports to be downloaded. In my case, the wait time was over an hour, but others have reported longer times.
