Page 489 of 495 FirstFirst ... 389439479487488489490491 ... LastLast
Results 4,881 to 4,890 of 4941
Thread: Mk7 Golf R Discussion Thread
  1. #4881
    Nov 2015
    Adelaide, Australia
    Hi all - just wondered what you guys think, I have a 2017 Golf R Wolfie that doesn't get driven much, short trips mainly & so only around 18k on the clock.
    Recently it developed a coolant leak, it's just out of warranty but VW were kind enough to deal with under warranty as a goodwill gesture.
    However, I was shocked that it's a $1700 odd fix to do so very relieved not to be doing it under warranty.
    My question is, if I'm driving the car this infrequently, am I likely to keep running into this sort of problem? The service guys told me that it's a by product of not driving the car often enough that the seals can dry out a bit & fail. Wondered if anyone can comment on this.
  2. #4882
    Sydney Northern Beaches
    Sadly, this is very very true.
    A car will deteriorate (in the mechanical areas) very quickly indeed if not driven.
    I have a couple of cars and you need to get into the habit starting them and driving them at least once a week. If you cant drive them then you must start them up to engine operating temp at least every week.
    In the Second world war. The German Tiger tanks had to be run for 20 minutes every day or they would simply never start again. Things have changed but maybe not that much.
    The Car: MY20 Black Golf R Final Edition, 5 Door, Driver assistance package, Sun Roof.
  3. #4883
    May 2012
    Brisbane, Qld
    Quote Originally Posted by CaptainCaveMan View Post
    Hi ...what was the exact nature of the leak. MY dealer has said my MK 7 GTI PP has " thermostat housing starting to leak" cost to fix with some goodwill on the parts is $750 ...car is a 2016. However there is no leak visible to me and the coolant level hasnt dropped.
  4. #4884
    Canberra
    This is total BS IMO. The thermostat housing on the EA888 engine is simply just a crap design.
    Despite VW making many changes to fix the problem (there have been multiple "revisions" to the part) they continue to fail, regardless of how much or how little a car is driven.
    There is a constant stream (pun intended) of reports of these leaking coolant and needing fixing, so much so that a cynic (like me) can only speculate that it is a deliberate ploy by VW to increase both their profits (by selling parts outside of warranty) and that dealers are complicit in the scam because they are getting paid for the labour (whether in or out of warranty).
    If VW were serious about fixing the issue they would have redesigned the part/s so they no longer failed.
    It is true that seals can dry out and fail on cars that are not driven for long periods, but I do not believe that this is the cause of the problem with thermostat housings leaking coolant. I note that there are no external seals on rotating shafts that are causing these leaks.
  5. #4885
    ^ i agree with the above. VW/Audi/Skoda waterpumps and thermostats are a common and consistent failure amongst all models. They are a rubbish design, no doubt engineered to fail, and being made out of plastic - while it makes them lightweight and cheap to manufacture, makes them prone to crack and become brittle with years of heat cycles.
    2017 Ford Fiesta ST
  6. #4886
    May 2012
    Brisbane, Qld
    I wonder if there is an aftermarket alternative option ?
  7. #4887
    Canberra
    Quote Originally Posted by jdw View Post
    Not that I've heard of - yet ....
  8. #4888
    There is (traditional cast aluminium) for Mk5 and Mk6, but nothing I am aware of for the Mk7 yet. Im sure someone will make something at some stage though.
    In the meantime you are forced to replace a crap part which is designed to fail with an identical crap part which will do the same.
    2017 Ford Fiesta ST
  9. #4889
    Speak of the devil....mines leaking. 2015 Mk7 GTI. Only a very small leak at the moment so ill clean it up, top up the overflow tank and monitor it over the next few months. The car is getting its major 60,000km service next week so not exactly keen to spend an additional $1k+ on a water pump yet.
    2017 Ford Fiesta ST
  10. #4890
    Jul 2009
    QLD
    HGP Stage 1 8R Includes modified ECU DSG tune modified series Turbo 444 PS 564 Nm stock exhaust check out the video
    Mein Fahreindruck: HGP Golf 8 R 444 PS - Zeiten messen, TopSpeed, Sound und Wägung ????(Teil2/2) - YouTube
    2017 MY18 Golf R Wolfsburg | Oryx White | DSG / 2021 MY21 T-Cross Style | S+V Package | Limestone Grey
