Page 19 of 33 FirstFirst ... 9171819202129 ... LastLast
Results 181 to 190 of 326
Thread: Maps update
  1. #181
    Pacific Paradise QLD
    Works without Discover Care as well Is ver 88
    If you have Discover Care on your computer it will find the new map .Have just started the download
  2. #182
    Apr 2018
    Quote Originally Posted by Flipper Dog View Post
    Discover Pro version P88
    Attachment 48544
    Location - http://infotainment-cdn.skoda-auto.c...ROW_202022.zip
    Tips for young players:
    Download with a download manager
    Don't use Apple
    Extract directly from the Zip file to your SD card
    If at first it won't work reformat your SD card and try again
    Is it better to get the Skoda version or the VW version direct from the VW website ?
    https://vw-maps-cdn.lighthouselabs.e...IBH3_ROW_NT.7z
  3. #183
    Any of the links above will give you the map It is the same thing on each site but has a slightly different name . Thats all so take your pick
  4. #184
    Sep 2012
    I had no problems running it through DiscoverCare last year but getting checksum error yesterday. 40gb free harddisk space and 32gb sd card formatted as Fat32. The log was showing the following.
    2020-07-11T11:47:44 [Info][General] Delete backup: C:/Users/pc-use/DiscoverCare/Backups/{2e67d797-8fbe-42de-a875-5b828c942ab9}.mapbackup
    2020-07-11T11:49:42 [Info][Download Manager] Set UI NOT_STARTED
    2020-07-11T11:49:47 [Info][Download Manager] Start Download_SL
    2020-07-11T11:49:47 [Info][Download Manager] Set UI RUNNING_DOWNLOAD
    2020-07-11T14:33:25 [Info][Download Manager] Download finished: SUCCESS
    2020-07-11T14:33:25 [Info][Download Manager] Set UI RUNNING_MERGE
    2020-07-11T14:46:32 [Info][Download Manager] Merge was successful
    2020-07-11T14:46:32 [Info][Download Manager] Set UI RUNNING_CHECKSUM
    2020-07-11T14:48:05 [Info][General] R:e05d668f4a1a3bc8fd8a1884637dddc2
    2020-07-11T14:48:05 [Info][General] C:9d3e11692ecbbb50dc89e8bd4ea7e3d3
    2020-07-11T14:48:05 [Info][Download Manager] Vorberrechnete Prüfsumme -> e05d668f4a1a3bc8fd8a1884637dddc2
    2020-07-11T14:48:05 [Info][Download Manager] Prüfsumme Berrechnung -> 9d3e11692ecbbb50dc89e8bd4ea7e3d3
    Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
  5. #185
    Apr 2018
    Thanks mate. I will try the VW first. Do you know if the VW version is the same date version as the Skoda ?
  6. #186
    Quote Originally Posted by FastMitch View Post
    AS I said they are IDENTICAL absolutely and completely Its the version number that matters dont worry about dates It VER 88 on both
  7. #187
    Quote Originally Posted by Rooboy View Post
    Just download the file from the link in thereply above yours . Unzip it using a PC and copy the folder to your SD card Shove it in the car and Voila it works
  8. #188
    Apr 2018
    Is there a Windows Program called Discover Care ?
    If so, do you have the download link or are you supposed to receive the software when you buy the car ?
  9. #189
    Discover care used to be on the Portal but seems to have problems ATM so those of us who have used it before, downloaded it and run it from the PC as would be normal I would think
    A lot of fluffing around about all of this Just use the direct links to the actual file and do as I said in my last reply. I rarely bother using it as its often faster the other way
    You posted the link yourself so what happens when you use it.
  10. #190
    Apr 2018
    Downloaded ok (very large file). Will let you know when I apply the update on the tiggy.
    How does the version numbering work ? What does the P88 stand for ?
