MY08 Mk5 GT Sport - sold
Further to my previous post, this links will create convert your POI's for installation from a SD card or USB:
Collection of POIs
I found that when using the KML file format as recommended here > MIB II - Custom POI's / Speed Cameras etc caused an error message to be created "unhandled exception" in my browser ( I tried both Chrome and Firefox).
Instead I used the CSV format for Garman and had no problems getting the web plugin to convert the POI's and install them via USB (using only the generated files in the "MIB2HIGH" directory in my case).
All my speedcam related POI's (Fixed, point to point, mobile etc ) are all viable on my screen.
The problem I have is there is NO audible warning. And yes I did select the tick box to create audible warnings for my POI's when using the converter.
If any one has any ideas why, let me know.
Perhaps it is a moot point as others who do get the warning have reported that
1) the warning is fairly faint, and
2) the warning comes at the last moment, too late to slow down or whatever (and apparently there is no way to adjust the parameters for the warning to sound sooner).
Yes, it's an annual subscription. The amount depends on which packages you want. There are many iphone and android Apps in conjunction with CarNet. With one App for example you can remote start the car from anywhere in the world, lock/unlock the car etc.
There is an emergency services subscription which automatically dials police/fire etc if you have an accident.
I believe auto maps update is part of the basic package.
Problem with Oz Cars, we don't have the SIM card slot between the two SD card slots. All European cars have a SIM card slot. You can however, use a WiFi link to your phone to gain internet access which is what we're able to do here in Oz.
I used VCDS to enable all CarNet functions on my new DiscoverPro on my Golf 7.5 but unfortunately all online functions go through VW CarNet. Without it, nothing works.
Search CarNet on Google.
Updates by CarNet in theory is a good idea, but not everyone has a 5gb data allowance on their SIM. Now if the car can be be linked to you home wifi (provided you can move it close enough) that would be OK.
I'd still rather download from my PC and install from a SD memory or USB.
Download took about 3 hours for me.
I must try the POI trick
Hi All
I have a MY2018 Golf R Mk7.5 built December 2017 and was using this thread to see if I could create some Personal POIs containing Fixed speed, Red light and Safety camera locations for Australia.
As noted nothing worked for the MK7.5 Discover Pro in my vehicle.
I tried the following...
1 Downloaded files from poidb.com as at 24 June 2018
2 Used the Skoda site Collection of POIs to build the package of POIs (I tried .kml files but they caused errors so settled for .csv)
3 Frustratingly this package wouldn't load. Grrrr. Tried a few of the suggestions about flattening the file structure and only using files for my Discover Pro etc but none worked.
4 I then looked into the files generated and noted errors in the files describing file sizes. Edited them and Bingo!
I copied the contents of the MIB2HIGH folder to the root of the SD card (MSDOS-FAT32)
So if you have a late model Discover Pro hope this helps.
Includes warning warble.
No idea if this works for other types of Discover nav systems but I've included everything generated by the Skoda site.
<https://app.box.com/s/qf22zda1kon4vdpopghl1yj58pl6xmvn>
Please reply if you have success or not.
Enjoy
Golf R Mk7.5 MY18 7sp DSG
replaces Golf R Mk7 MY15 7sp Man that was totalled while parked😢
In MIB2HIGH/PersonalPOI/Package/0/Default/Hashes.txt the file size for each file is listed. These were incorrect.
In the metainfo2.txt file in MIB2HIGH directory there is an entry describing the directory
[PersonalPOI\Package\0\default\Dir]
The FileSize here was also incorrect. It appears it is the sum of the file sizes in that directory EXCLUDING the hashes.txt file
Also in the metainfo2.txt file I added the line
UserSWDL = "true"
to the [common] section.
I worked this out by comparing a working Personal POI package with the one I generated noting the differences.
When I get time I'll play a bit more and try changing the date that shows when loading the POI but its not that important.
Hope this helps and share your creation.
Thanks gtienvy
White MY17 Golf 7R with DSG and DAP.
