2017 Ford Fiesta ST
So I ordered from fcp euro just now. Supposedly should have it it just under a week to a week and a half.
Shortly after placing my order, vagparts replied after a few days, but good they replied. They appologised for not keeping up with emails. Good news is that they say they are awaiting their stock from Volkswagen US so I still would have had it long after the US order I just made.. Would have preferred to order locally seeing the cost was very similar, but not prepared to wait this time.
Here's to hoping the old pump has packed it in (which seems likely) otherwise the oil change and filter clean may have been enough. Means I only get under the car once this way, and figured it was 95% chance the pump had failed anyway.
So fcp euro delivered really fast. As in 4 days faster than expected.
Installed pump and cleaned the housing.
Reset adaptive values with obdeleven and took it for a drive. First up front wheel spin again. Feeling a little disappointed. Pulled over and reset values again. Did manual pump activation. Could hear the pump work.
Did launch control and absolutely no wheel spin. Woohoo its fixed. $300 fix only and an hour or so work.
Didn't look too bad at all. There was sludge in the bottom of the housing where the pump is but not on the filter. But I could tell the pump wasn't running as it made no noise and threw the fault.
I suspect that perhaps the previous mechanic (previous owners mechanic) changed the haldex oil and cleaned it but didn't realise (or perhaps change) the pump that had failed already.. The original fault date was early Jan which is when it got serviced last. So I suspect he either didn't realise what the fault meant, or perhaps the seller wasn't completely honest.
