Page 5 of 5 FirstFirst ... 345
Results 41 to 42 of 42
Thread: LED interior light upgrades
  1. #41
    Dec 2018
    S.A.
    Quote Originally Posted by notaGolfR View Post
    I'm sussing this out too. If nothing else I will be brightening the area above the bulbs with Al foil or white paper stick-on to reflect. I have found those areas are usually black!!! (DOH). If Al can make a "short" I will insulate. If the bulb gets hot I will not use paper. Our previous car had a lenticular cover meaning the interior of the fitting was not visible so I painted above the bulb with white correction fluid.
    I got a bulb out and they have a silver reflector built in but I added Al foil anyway as the bulb doesn't poke down far and shines on a dull black plastic surface. Good luck with brighter bulbs. The o.e. ones are a weird unusual design.
    cars (chronological) Morris850, Morris Mini DeLuxe, Cooper S, Mazda 1500SS, hard times so some old Holden, old Falcon Ute, better times so second hand Lotus Elan +2 (6 weeks, hopelessly unreliable) Chrysler Valiant Charger 770, second hand Datsun 260Z + 2 auto, Mitsubishi Cordia Turbo, Nissan 200SX turbo auto for 20 years(wonderful car burning ZERO oil after 200,000km & no problems when sold.. should have kept it), Toyota GTS 86 auto, now Golf R Mk 7.5 DSG built Aug2018, white.
  2. #42
    Dec 2018
    S.A.
    In the end I used correction fluid to "paint" the o.e. dull black plastic around the bulb as the foil might fall off. Tested in the dark of night it looks twice as bright as the un-modified rear lights so I'm very happy.
