Results 1 to 10 of 25
Thread: Kufatec module to permanently disable stop/start system
    Apr 2010
    For those who don't have [access to] VCDS
    Coding interface disable start / stop MQB-40019
    Sep 2010
    Perth
    Thought i'd resurrect this post.... Can anyone confirm if this works? Can we permanently turn off stop/start?
    PAST: 88' Mk2 Golf 16v GTI & 97' Mk3 Golf VR6
    CURRENT: 13' Mk7 Golf 103 TSI Highline
    Adelaide hills, SA
    It should be working, the Kufatec products are usually reliable.
    Nov 2007
    Isn't there a thread somewhere (I'm sure I saw it) where you can VCDS code out the stop-start? Adaptation of something to set operating temps (for the engine) for when the function will and wont work and then setting the threshold high enough that it never kicks in.
    Thats free, thus better .....
    Sydney/Canberra
    Or unplugging the battery module?
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Sep 2010
    Perth
    Anyone have a VCDS cable in Perth or WA that they're willing to let me use/show me how to use? Happy to compensate for time spent
    Aug 2007
    Also there are some mk7 vehicles like mine that won't accept the temperature codings. There is an alternative method now where you set battery voltage thresholds. concept is similar, set the low battery threshhold high enough so autostart won't kick in.
    Apr 2017
    belgrave victoria
    How to disable Stop/Start the easy way
    Hey guys i got this module online delivered from a stockist in melb in 2 days
    Just plug it in wait for the l.e.d to go out took about 5 sec with mine then start/stop disabled
    To reverse just plug it back in again same procedure
    Easy as no longer will start/stop **** me up the wall
    cost was $73 auzzie with postage
    Kufatec module to permanently disable stop/start system-20170802_163605-jpg
    Kufatec module to permanently disable stop/start system-20170802_163625-jpg
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
    Jan 2014
    Queensland
    Easier solution - Polo 6C GTI: How to Disable Engine Start/Stop - YouTube - it works the same for Golf 7
    hmm..........nothing wrong with Kufatec unit, but cheaper solution, without needing to use a diagnostic cable and without the "tell" that appears on the MFD when the car stops (i.e. the dreaded "A" with a slash) HERE
    I've been using mine for 2 x years now - never missed once - every time I switch-on the ignition, the SS Auto-kill switch turns off Start Stop and I can re-engage it easily at any time in my journey by simply pressing the SS witch on the console (not that I have ever done this - I reckon SS is the most dangerous thing in the car!)
    PS: For those that have an earlier model mk7, the "Voltage method" shown in SloAU video won't be available - instead \, you will need to use the "temperature method" - see HERE
