Page 16 of 17 FirstFirst ... 614151617 LastLast
Results 151 to 160 of 164
Thread: Golf Mk7 Towing/Towbar Thread
  1. #151
    Mar 2017
    Tasmania
    Quote Originally Posted by donweather View Post
    What I don’t understand is why can you get a towbar legally and VW approved on a normal golf but not on a golf R? They’re essentially the same car (body/structurally) apart from suspension and engine upgrades.
    Those are the rules of vehicle compliance.
    Canberra
    Some possible reasons:
    VW couldn't be bothered doing the calibration required for the ESP of the R (because of it's increased performance over a regular Golf)
    Tyre load limitations
    There is an undesired interaction with the R rear wheel drive
    Didn't want owners to get in trouble with the extra power of the R and a trailer.
  3. #153
    May 2020
    Canberra
    Has anyone seen an Ecohitch in action in Australia?
    Torklift Central | Select Your EcoHitch Style
    I'm most interested in the Stealth model, otherwise the Hidden will probably do. This will be for the bike rack on the GTI, no real towing to do so will not get a harness.
    They don't ship overseas, but you can use a service to buy it and ship it over.
    MY20 MK7.5 Golf GTI - Tornado Red - LP/S&SP
    MY19 AW Polo - Comfortline - DAP
  4. #154
    might have something to do with the route of the OEM exhausts
  5. #155
    Pacific Paradise QLD
    If you are going to buy a towbar at least get a euro one which has some cross certification here. Buy one of those something goes wrong and trailer disconnects and causes damage you could possible be sued for millions
    Westfalia bars are the best for VW and while they are hard to get here at present they can be imported and used LEGALLY
    Australia Tow Bars & Performance - CAN bus module wiring LED OEM kits - Brake controllers - Accessories - ECU remaps - Performance upgrades - Australia Tow Bars & Performance store
    https://etowbars.com/au/au/index.php...facturer_id=11
  6. #156
    May 2020
    Canberra
    Euro style towbars are fine if you are just towing a small trailer. I have a very good four bike rack and it needs a hitch.
    If I was happy with just a ball I'd get an original even.
  7. #157
    Quote Originally Posted by genebaby View Post
    Seems some are rated to 2500kg and 250kg on the ball Nothing wrong with that and will tow a 19 ft caravan at that limit
  8. #158
    May 2020
    Canberra
    How will they go with the 2" receiver on my bike rack?
  9. #159
    Was referring to your comment about only small trailers Obviously if you have a bike rack like that you need the ugly 50mm hitch.
    Remembering also that hitting a bump with 4 bikes on an extended hitch will put up to 7 times or more with 4 bikes of the static weight on the towball area
    Have seen a few bikes lying on the road after they have broken off bike racks on the rear of vans for that very reason
  10. #160
    May 2020
    Canberra
    I can only imagine what kind of setups they might have had.
    A good rack won't have that problem.
