Thanks Don.
Waiting on the car to arrive, and then all the parts!!
^^^^^^If you put the remote in the space next to the fuse-board, you can use the remote's native battery instead of the car battery because access is relatively easy - simply drop the glove-box. Yes, a generous 1m should be long enuff,
Thanks Don.
MY20 MK7.5 Golf GTI - Tornado Red - LP/S&SP
MY19 AW Polo - Comfortline - DAP
Hi, I ordered a one channel Double Apex integrated garage door controller for my 7.5 R. DA emailed to say it’s not compatible with my controller so cancelled the order and refunded me. My controller is an old school Elsema FMT 201 operating at 27Mhz. Has anybody dealt with this and found a solution?
I sticky taped my opener to the inside of my door pocket cant be seen and falls to hand . If car is sold ever its easy to remove and not have to pull things apart.
Nice! Any particular tape?
On a seperate note I have the 2 channel 750 S cameras and despite switching off parking mode it still continues to record and draw down my battery. I’ve done all the resets etc and I’ll contact Blackvue but thought you may have an obvious solution I hadn’t thought of.
It’s hard wired with a Power Magic Pro. The problem is it continues to record in park mode when I’ve supposedly disabled it. This also means it only records for a couple of hours before the voltage regulator cuts in. I’d rather it wasn’t recording in my garage when not meant to and record for longer in airport and supermarket car parks etc...
My brand new Elsema 201 doesn’t work from the door pocket of the 7.5 R. The 35 year old cigarette pack sized one does. I then tried the new one on the right side wall of the 4Motion cubby in front of the gear selector without joy.
It works and fits perfectly in the otherwise useless space in front of the USB port.
Just in case anybody else has a similar problem...
Hi @DV52, I just came across this guide and think I've got the gist of most of it. Could I double check with you that the new connectors that we're inserting into the wiring looms for connectors #9 and #10 are going to be connected to the garage remote switch (connected to the terminals where the original garage button sits). Thus, when we hit that new tire button, connectors #9 and #10 will close the circuit and trigger the garage opener to activate? Cheers
