Originally Posted by
genebaby
Is there a way to turn the original blank into a working button, but still stay blank?
I'd rather it looked like it had no function. Is that possible?
Thanks
genebaby: Hi - I'm surprised that this DIY project is still of interest after all these years!!
Anyhow as to your question - my suspicion is that the short answer is No (at least not for OEM switch banks).
The longer answer goes something like this - below is a picture of the underside of a "working button" and a "blank button". I've also included in the picture the switch insert that is used by the working button to reach the rubber pad at the bottom of the housing. The rubber pad presses up against copper traces on the printed circuit board (also located at the bottom of the housing) creating the physical switch.
So, clearly the underside is very different for the 2 x plates. To further explain how the OEM switch operates, the tag that I have circled on the switch insert slots into the square hole that I have circled on the inside of the working button. To make a blank operate as a working button, you will need to re-create these recesses.
I recall trying to do something like this in my first attempt at this project without success. But perhaps you have better fabrication skills!!
