Originally Posted by
DV52
Matt: Clearly I have chosen the correct co-inventor. As a well known Jedi gnome once said "strong with this one - the enthusiasm is"!
On a more serious note. Just get hold a couple of sewing needles and shove them into the connector space, attach the multi-meter leads to the bits that stick-out! I agree with your method of approach - better to connect to the back of the switch module.
If you look at my post#1, you will see that the signal wire to pin #4 is black/blue. You should see this colour wire in the rear of the connector loom (on the opposite side to the Black/Yellow wire.
If I could be so bold as to suggest a simple test before you connect the S/S kill switch to the Black Blue wire . Using those sewing needles that I mentioned earlier, pierce the Black/Blue wire with the sewing needle so that the tip goes through the copper wire. Then hook-up the multimeter leads to the needle-end and the other lead to an earth point. With the multimeter on DC volts, then press the VW S/S button and check that you have a short to earth. If you get this short every time that you press the S/S button, you have the correct wire. Incidentally, I have no idea what voltage the multi-meter will read with the S/S switch not depressed - please tell me
