Same here.
And without reading through the previous 4 pages, is this applicable to a TDI Highline? Or do I need more parts?
Printable View
Same here.
No idea re Hi Line may need different door controllers... the parts were approx $750 to buy... not including the Hex Can cable I have from Rosstech
This is really interesting. I might do this for myself,
Do the left mirror dip when you reverse?
Great work, I haven't had a chance to do any further resarch for adaption of the navigation to bring up mirror options. it will no doubt be a coding issue.
Lock the car by holding down lock and the mirrors fold on my golf r. If i lock the car by touch handle (golf r kessy) it won't fold on lock. It might be a bad idea to fold on lock as sometimes i park so close to things that it would smash my mirror if it tried to fold.
*edit* just noticed that you had the grabby thing. We didn't have one, what a mission!
Mirror actions are the same as standard mirrors on your car
This is truly outstanding peekay. All in all how long did this take you to complete?
I also didn't realise the puddle lights come standard with the folding mirrors.
Just to confirm, where did you order your parts from? Are they all from USP Sports?
OK so an update all of a sudden my mirrors would no longer Fold in via my the remote after working for over a week. After hunting around I finally found something that helped and it is now fixed. Thanks to the finder of this on the other forum ......as I was left scratching my Head.
So after hunting found some more coding that is required. You have two options to fold on Lock or Fold by remote. The USP coding instructions are not enough. Again you need a Ross Tech Cable....or simular. A full dump of this can be found at
VWVortex.com - USP Folding Mirrors VAG-COM - Fold automatically upon locking - Instructions
VCDS:
Choose "Select control Module"
[09] Central Electronics
[16] Security Access - Code is 31347, click "Do it!"
[10] Adaptation, choose from the drop down channel
[23] - Access control 2 - Funk Spiegelanklappen change to "active", click do it
[26] - Access control 2 - Menuesteuerung Funkspiegelanklappen change to “active”
[24] - Access control 2 - Funk Spiegelanklappung Modus change to “by look command via remote control key” this will fold the mirrors on lock.
[24] - Access control 2 - Funk Spiegelanklappung Modus change to “via convenience via remote control key” This will work ensure function works via remote (which is what I selected as I don't need them to fold all the time)
HI Mate do not order from USP the offsets are incorrect and they will not function correctly....... Also the switch is wrong is for left hand drive cars...... IF you want them I got mine from South Yarra Volkswagen..... Adam ordered them
Well done Peekay34, great write up and effort.
This is definitely on my list to do to mine.
I ordered the folding mirror modules listed in this thread for my highline yesterday.
thanks for the write up peekay34, I cant wait to try this on my car :)
