Results 1 to 6 of 6
Thread: Static cornering lights
    Hi guys, my MY15 GTI just has halogen lights, and does not have any form of cornering light. The dealers tell me the halogen equipped Golfs don't have them but I'm pretty sure I read somewhere that there should be a static light, presumably using the fog lights. Is this something that can just be activated via VAGCOM?
    Golf GTI MY15 Night blue metallic
    Polo 6R MY15 Black
    Quote Originally Posted by Merlin8r43 View Post
    Merlin: Hi.
    I'm surprised that the MY15 GTI Halogen fittings don't have static corning lights - my bog-standard MY13 TSI had them factory fitted. But then, I have never been able to fathom how the marketing boffins at VW Australia make these types of decisions - probably in a darkened room with a Ouija board and smoking ganja weed cigarettes (let me leave you that mental image)!
    Anyway, as to your question, it most certainly can (and should) be done with a VCDS cable. The Leuchte programming changes are very simple, but there may be some additional adaptation channels in the BCM that require tweaking (for the steering wheel turn-on/ turn-off angles. I'll have a look at my database and report back
    Legend! Thank you sir.
    Polo 6R MY15 Black
    Merlin: OK, had a quick look at the admap for the BCM on my car and here's what I think:
    1. There don't appear to be any specific adaptation channels devoted to the steering wheel angles for the static cornering lights. I suspect that the BCM uses the settings for AFS (Advanced Frontlighting System that is used for dynamic cornering on HID headlight fittings). All the admaps in my database have the AFS pre-set as default (regardless of whether HIDs are fitted), so I'm guessing (hoping) that your BCM is similarly coded.
    2. I've manufactured (guessed) how the two Leuchte-sets for the left/right fog lights have been set-up by the factory in your car. If my hunch is correct, your car should have the "old settings" shown in the tables below. You must check that my guess is correct and If I've erred, please provide feedback.
    3. The tweak instructions are as follow:
    1. Select 09 - Central Electr control module
    2. Select Security Access - 16 from the "Open Controller" screen
    3. Enter the magic number 31347 and return to the "Open Controller" screen
    4. Select Adaptation - 10 from the "Open Controller" screen
    5. From the pull-down button check that the default settings for the adaptation channels shown in the table below are as indicated in the Old setting column. Use the "search box to find the correct Leuchte channels
    6. Change the two Leuchte channels depicted in the table below to the values in the New Settings column. Don't confuse the new settings with Abblendlicht links/rechts command - the two may look similar, but they are very different in their functions
    Wow, thanks DV52, that's a lot of trouble you've gone to! For my next question, where can I get the software and cable these days? Older posts say Dubaddiction but I don't see it there any longer. Alternatively, anyone in Sydney with the gear willing to help a Golfie out? Name your drink of choice.
    Polo 6R MY15 Black
    Merlin: No trouble at all- my pleasure!!
    Here's the official Australia distributor list from Ross Tech
    Eurospeed
    132 Boronia Road
    Vermont, Victoria 3133
    Harding Performance
    11 Castlemaine Street
    Coorparoo, Queensland 4151
    Int'l: +
    61 7 3394 1200
    Local: 1300 730 949
    Fax: +61 7 3847 4394
    Mount AutoEquip Pty Ltd
    U13, 122-126 Old Pittwater Road
    Brookvale NSW 2100
    Tel +
    61 2 9905 8055
    Fax +61 2 9905 8022
    But if you only want to do this tweak, then it's better to use your forum buddy option!! You might have greater success asking at the thread HERE. If you want to come to Melbourne, I'm more than happy to do the tweak for you!!
    Cheers and good luck!!
