Results 1 to 9 of 9
Thread: Lose ECU In MK7 R
    Jan 2012
    Lose ECU In MK7 R
    Hey I was just having the usual engine bay and fluid check the other day and noticed my ECU inside that locked black steel case is lose and wobbles about. It’s the first time I’ve noticed this and just want to make sure either it’s normal or it should be secure. I can grab the wiring look that comes out the front and shake the ECU.
    2015 Golf R. Lapiz Blue.
    Mar 2014
    Newcastle, NSW
    I can check mine today by I recall it being rock solid.
    Mk 7 R Wagon Wolfsburg. APR Stage 1. Removable towbar.
    Jan 2012
    Cheers mate.
    Jan 2008
    It should be solid - not sure if there’s a bracket though or how it’s affixed
    The battery has a bracket at the bottom front holding it in place
    2006 MkV 2.0TDI -> 2005 MkV GTI -> 2008 MkV R32 -> 2013 Polo 77TSI + 2016 Mk7 Golf R Wagon
    Has the car been chipped? If so, some companies need to remove the ECU in order to tune it and they may not have put it back correctly.
    Jan 2012
    No not been chipped, my thoughts is though it should be solid.
    Quote Originally Posted by Reedy View Post
    It certainly shouldn't be loose - perhaps what ever clips or fasteners they use to secure it have broken or worked their way loose? You will need to have a poke around under the bonnet to see whats going on.
    Mar 2014
    Newcastle, NSW
    Checked it. It’s solid as. 5mm lateral movement as the frame flexes on its attachments. 0mm fore and aft.
    Jan 2012
    Thanks everyone. I’ll book it in.
