Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: VW Golf MK7 - 2022/06/20 official map update
    Lightbulb VW Golf MK7 - 2022/06/20 official map update
    Need your help with my VW Golf MK7 Highline.
    I attempted to use the 2022/06/20 official map update from the following. However the file is 25GB and my SD card is only 8GB!
    The update didn't include all the other countries previously I'm sure.
    Has anyone completed the latest update? What am I doing wrong?
    The issue is I have wiped my card and I can't restore the navigation. Does anyone have a working copy of an update? I really need to restore navigation. Thank you.
    Volkswagen Map Updates
    Golf until 2015
    Discover media
    World
    Updated: 2022/06/20
    File type: zip
    Coverage: Argentina*, Australia, Botswana*, Brazil*, Brunei*, Indonesia*, Israel, Lesotho*, Malaysia, Mexico*, Mozambique*, Namibia*, New Zealand, Philippines*, Singapore, South Africa, Swaziland*, Thailand*, Turkey*
    * partially
    Jun 2007
    Sydney, Australia
    Discover media or Discover Pro?
    If you are needing the VW SD card to operate it then that would be the Discover media.
    You need this link https://navigation-maps.volkswagen.c...M3_1910_V16.7z
    The June 2022 version for SD card and only 5.29 GB
    Flipper Dog
    Now - T-Roc R, Audi Q5
    Apr 2022
    New Zealand
    Flipper Dog. How do you install this, is it a copy and paste exercise?
    I had previously updated my SD card using the Discovercare app, but it doesn't pick up the 2022 map update, only the 2020 one which I have so says the maps are up to date.
    Thanks
    Jun 2007
    Sydney, Australia
    @hoskurner
    If you have MIB1 (pre 2015 Discover media) than try this link.
    https://navigation-maps.volkswagen.c...S5MIBH3_ROW.7z
    Flipper Dog
    Apr 2022
    New Zealand
    Quote Originally Posted by Flipper Dog View Post
    @hoskurner
    @flipper Dog what parts of the 24GB file do I need to copy over, as the SD card with the car is only 8GB?
    Thanks
    Nathan
    Pacific Paradise QLD
    Quote Originally Posted by hoskurner View Post
    Thanks
    Nathan
    You have to use all of it as it downloads or it wont work. Or you could be trying to use the wrong map
    You are trying to download the wrong map. The 24gb one is for a different nav unit
    The one Flipper Dogs reply no 2 is the correct one. Download it to your HDD and COPY the whole thing to the SD card
    Jun 2007
    Sydney, Australia
    Sorry I can't help you there. Didn't realise it was so large.
    You could try the SDS folders and remove all the languages except English but I don't think that would lower the contents by 2/3.
    I have not seen the folder structure on that download.
    Make sure you save your current map contents and try playing around removing some country maps on the latest version to reduce the size, it may work, it may not.
    The other option is to seek out a SD card from Europe on a market place web site, they are 32GB with the current maps on them.
    Have you tried Discover Care ?
    DiscoverCare Download - Provides the latest map updates for Volkswagen navigation systems
    Flipper Dog
    Seems he has a Media which has a VW card and uses much smaller maps than the Pro which has the 25GB map and loads it into the unit. If he has wiped the SD card he is in trouble as that shouldnt be done and just a map may not fix it.
    As I said I think the correct one is in reply 2.
    Also have never seen a map you could edit it and still work.
    All have to be loaded as the complete thing and the location just uses the map needed
    I tried a long time ago to delete countries and map never worked till I installed the whole thing.
    Try reply 2 link as it seems to be correct as Im downloading it and it is a map for Media not Pro
    Ive just gone to the update portal and the map in reply 2 is the 2022 map for a Discover Media for a Golf from 2015 on It is 5.3 gb
    Apr 2022
    New Zealand
    Hi Hillbilly,
    Just looking at your last reply. My car is up to 2015 as it is a 2013 car not after 2015. If I select that on the map update site and the discover media unit not the pro, it gives me a 24gb download.
    Am I doing something wrong here!?!
    Thanks
    Nathan
    Hi Hillbilly,
    Thanks
    Nathan
    As I have already said. go to reply 2
    and click on that link it is for PRE 2015 DISCOVER MEDIA and is 5GB.
    Also some 2013 units had problems and required an update from the dealer.
    That link is for units that HAVE to use a VW branded SD card and nothing else so if your card has a VW part no on it thats what you should do AFAIK. I could be wrong but if your car only has a small capacity card you wont be needing the 24GB map
