Yes, the battery has to be coded in with scanner or a special tool.
So after getting a battery low message on my golf mk7 and the stop start not working i replaced my car battery with another AGM which has the same specs etc.
Anyway stop start still not working and i copped another battery low message today.
I've googled and some people say i need to code a new battery so it "relearns the battery". Any truth to this?
it's done like this (for VCDS) and very similar for OBD11 - this depends of course on whether your new battery has the BEM data. If it doesn't, then enter as much data as you can and just make sure that you change the "notional serial number"; it's generally a string of 1's as set at the factory -so just change one of the 1s to zero.
Note: MQB platform vehicles like the mk7 use UDS protocols - so start the video @ about 4:47 minutes
I've changed the batteries on both of my keys and they both worked fine with no coding required.
MK7 Golf GTI 40 Years | Carbon Steel | DSG | Front Windows Tinted | JB1 (Map 6) | Sunroof | Folding Mirrors Retrofitted | Current
W211 E55 AMG | Previous
No, the actual car battery.
I changed one the other week without coding. As far as I know, the car hasn't spontaneously combusted yet. Start/Stop worked, charging system worked, no fault codes logged. Yet to see a definitive reason why it needs to be done, besides German bureaucracy.
I'd say test the new battery.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
The battery died on my car and had the dealer replace it under warranty. If your car still has warranty try the dealer first. have to be force full.
VW are good at engineering their cars. Both batteries in both cars died 1 month and 2 months after the 3 year warranty expired.
They dont make the batteries though They buy them in usually from Bosch
