sprint_ed: You probably don't want to hear this, but I've done the SS tweak on a number of cars and they have all been successful. However, all the cars have been mk7 Golfs. I'm not familiar with the Caddy and you didn't say which version that you have. Without a copy of the autoscan report it's difficult to make any specific comments, but a few things that you could try:
- Are you using the latest RT software (perhaps the latest beta version 14.7.2)? I assume that you have done all the usual stuff like a search of the net (sorry, but I had to ask)
- Has the VCDS software supplied "labels" for all the module control on yout car (i.e. as shown in the autoscan report). If this is the case, and if you have examined all the long-coding screens and found no mention of bits/bytes relating to the SS facility, then it's fairly safe to assume that the answer (if at all) lies in an adaptation channel somewhere.
- Have you produced a complete suite of Adaptation maps for the car? I'm not sure if you are aware of these, but the RT instructions for these maps can be found here. Remember to select "adaptation" and "CSV" before running the map software and a note of caution: the maps on some of the controllers (like the CAN Gateway for example - I assume that the Caddy has a CAN bus) can take a long time top complete - so make sure that the laptop battery is fully charged.
- Once you have a set of .CSV files for each controller, parse them into a spreadsheet application (like excel) and search for the term Stop/Start (or Stopp as per the term in the mk7 ). That should give you an idea if there are any adaptation channels in your vehicle for this purpose. Look here for the adaptation map spreadsheet for my mk7 - just as an example.
- If you are not comfortable with excel, then you could try simply searching through the individual .CSV files using the "find" command in a text editor software like MS notebook. It's a bit more tedious, but it does the job.
- failing all the above, the answer could be that the Adaptation channel for disabling SS on the Caddy is in one of those "hidden menus" what we all dread. Finding the coding byte to unlock this problem is a lot more tricky, but let's hope that this step isn't required!
- Finally, you could make enquiries about the KUFATEC module. It's intended for MQB platform vehicles, but a email to the distributor might bring some joy. The link for this product is here
Good luck and my apology if you already know this stuff. Please let me know how you fare
