Results 1 to 2 of 2
Thread: Need a MK7.5 admap!
    Jun 2018
    Need a MK7.5 admap!
    Hi All,
    I upgraded my BCM to a mk7.5 (I have a mk7) a while ago but always had few coding that needed to be tidied up. Any one with a mk7.5 4 doors (the one that I got cam from a 2 doors and I think that's the cause of a could issues that I having right now) that could please taka an admap and provide to me? I'd really appreciate as well. For reference my current BCM is 5Q0 937 084 CP.
    Thanks a lot!
    Guto.
    Golf Wagon MK7 (90 92TSI) - Mods: DQ250 swap (Stage 2), 110TSI turbo upgrade (Stage 2), Bilstein B12, 19" Pretoria, GTI PP sway bar upgrades (front/rear), full GTI tartan interior, GTI color cluster, R Bi-Xenon headlights with AFS retrofit, GTI brake upgrade.
    More to come...
    Guto: Hi.
    Best that I can do is 5Q0-937-084 CQ - it's from a MY18 Aussie Tiguan - Download_here
    If you want the adaptation channel that tells the BCM that it's installed in a 4 door vehicle - look at the very last entry in my ADMAP:
    • ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer (translation: ZV Door configuration-four doors)
    As set for the original 2 x door donor car, the value will be No - of course once the BCM is installed in your car, the value should be Yes
