Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: Coolant leak
    Sep 2012
    Townsville
    Coolant leak
    Hi all not sure if we have covered this topic but my golf 7 TDI brought up the low coolant warning. It's only 6 months old with 10000km on the clock... Checked level and it was well below the min level line. I have not noticed any leaks. Has anyone else had this problem? If so what it a simple fix. It's going into the dealer but I am worried they will just top it up and say there is nothing wrong....
    Any thoughts/advice would be great
    2014 VW Golf TDI Highline DSG - Limestone Green, DAP, Xenons
    2018 VW Golf R Hatch DSG - White Silver, DAP , Dynaudio
    2016 Skoda Superb 140TDI - Family Members
    2013 VW Amarok TDI420 Highline Auto - Family Members
    Jun 2011
    Sydney NSW
    You may have to take it to a cooling system specialist. They can pressure test it and see if the system is holding pressure (hence, not leaking).
    Have you checked the oil for any discolouration? Leaks do not have to be external. You can get a leak between the water jacket and an oil gallery, or even the combustion chamber. The thing is that for the combustion chamber, this would also pressurise the system, so you would see it overflowing from the reservoir.
    Apr 2010
    Geelong
    Take it back to VW. If there are any problems it is their responsibility under warranty. A cooling specialist will (quite reasonably) have to charge you to test it.
    2010 Mk VI GTI-Red/Manual/Detroits/Park assist/Leather/MDI/Sunroof/Bi-Xenons/Chassis Control/Elec Driver's seat/5 Door/Tint
    2009 Triumph Street Triple R Matte Blazing Orange
    1971 Mini Clubman GT
    Some coolant loss over 10000 km would be expected, especially in a new car. It's very rare to have all the rubber water pipes sealed 100% as the car ages. Get the dealer to check and tighten all the clamps and keep a check on the water level at least monthly.
    Or you could grab a screwdriver and do it yourself.
    Paul
    Nov 2009
    SEQLD
    A week after delivery of our GTI I noticed the coolant was on the minimum mark. Booked it in and they pressure tested the system and topped it up.
    System tested fine. They told me it probably was an air lock from factory which is why the level dropped. I've been checking the header tank every week and it hasn't gone done in 5 months 7k Kms.
    MY20 Golf GTI TCR
    MY20.5 LR Defender P400 HSE
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by irossiter View Post
    Agreed.
    Don't buggerise around with independent shops over a potential warranty concern. You won't be reimbursed.
    It's VW's warranty, only they can honor it. The dealership will have a coolant pressure tester.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jan 2013
    Brisbane, QLD.
    Let's not scare the poor fella. Just book it into VW, some levels e.g: oil and coolant dropping while in run in period (for any make, model etc) is completely normal.
    Jun 2008
    Sydney Inner West
    My TDI has done the same thing. Einstein at the dealership has pressure tested the system and says it's fine, he went on to say it's a common problem with the TDI's - I'm not entirely convinced, this is my 3rd TDI and it's the first one to use coolant.
    It's now all over the service records and it will be going back to the dealer in a couple of months if the coolant level drops again.
    Ditto go back to VW now......
    Dec 2008
    Sydney/Canberra
    Some of the TSIs used to burp a bit of air out, causing the level to drop once they were delivered and being driven on the road.
    '01 Beetle 2.0
