@ Siggy
Firstly we need to confirm what system you have.
Is it an MIB1 or MIB2?
MIB1 will NOT have car play/android auto, where MIB2 will.
Then we need to establish if it is a Discover Media or Discover Pro.
Discover Media will have a SD card used in media slot number 2, by the sounds of it that is what you are playing with.
Discover Pro will have your maps loaded internally into the unit. You need an external source to load such as an aftermarket SD card.
If you have the MIB1 Discover Media system and you are having problems, then you need to seek assistance from your dealer. There is a software update required to allow the SD card to load the maps from the Volkswagen Map Update site.
If you have the MIB2 Discover Media system (maps loaded only on SD card to work) than follow these instructions -
https://app-connect.volkswagen.com/m...ember_2020.pdf
unzip the file to your computer and then copy over to your SD card.
There will only be a main folder [maps] then 5 x sub folders [22,23,26,27 & EEC] no text file until you break down the 22 (etc) files - eg: 22/cfg/mapcfg/VW/variant. That being the only text file.
The OEM SD card will have hidden folders on this card that will remain when the card is formatted, if you try and use another non OEM SD card it will fail.
Place the SD card into slot 2 only and the map should automatically be read by the system.
If you have the Discover Pro than follow these instructions -
You will need your own SD card of 16 or 32 gb and this will need to be placed into slot number 1 and loaded into the unit via the software update function in your setup screen.
Good luck.
