Results 1 to 5 of 5
Thread: 2013 Golf MK7 90tsi DSG - airbags deployed at less than 10km/hour - help please
    Oct 2012
    Tasmania
    Hi.
    Just wondering if this should have happened.
    My partner was stopped at some lights behind another car, got distracted and took her foot off the brake and the car went forward (dsg) into another car and the passenger airbag, driver airbag and drivers side near the pedals airbag deployed.
    Is this normal..? is it a fault..?
    The person who she hit, basically didn't know she hit her and the police who attended were bewildered at the damage (passenger side airbag broke the windscreen).
    Guessing it is probably going to be a write off, but wondering if I should contact VW about the airbags being deployed..?
    Dec 2008
    Sydney/Canberra
    That's unusual.
    Has the car been in an accident previously?
    It's normal for the passenger airbag to break the windscreen, as it's quite tall when it's fully inflated.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Oct 2012
    Tasmania
    Quote Originally Posted by Umai Naa!! View Post
    That's unusual.
    No previous accident as far as we know. Just seems odd as even if she accelerated she couldn't have travelled for more than a metre....
    Quote Originally Posted by Krusty900 View Post
    Hi.
    Krusty: Accurately understanding what happened in an accident where the airbags have deployed is an arcane science - as well as being a bit of witchcraft! So it's very unlikely that that anyone here will be able to help (no offense intended to Umai Naa whose knowledge of VW stuff is impeccable and without peer on this forum).
    But perhaps the picture below will help in understanding the degrees of freedom that the mk7 uses in making the ultimate decision to fire-off the pyrotechnic igniter in the air bags:
    As you can see, airbag deployment is quite a sophisticated decision making process that is ostensibly controlled by the module labelled J234. The algorithm that J234 uses for this purpose is a balance between a quick response in a severe frontal collision and the avoidance of deployment in less hazardous cases. But there is information from multiple sensors that is used in the decision making process.
    I'm by no means an expert of the mk7's algorithm, and without wanting to understate the sophistication of the system, my understanding is that airbag deployment is all about measuring deceleration and listening for certain frequencies in the car that are formed during the fast deformation of supporting structures in the front end of the vehicle. Again, my understanding is that these frequencies spread through the body structure at high speed and very quickly provide precise information about the severity of the crash. It's a bit like an echo sounding system in a submarine except that J234 is a passive listening device
    As the picture above also shows, there are acceleration sensors and front door pressure sensors placed at strategic locations in the mk7 which also contribute to the airbag deployment algorithm.
    As to which of these inputs to J234 was the most critical in the decision to deploy the airbags, the answer can only be found by interrogating PIN #15 (see the wiring diagram below) on the car's OBD port using a special device - which is very different to diagnostic devices that lot's of us "nerds" use (like VCDS)
    Unfortunately, the cost of even the most basic airbag control module reader (see HERE) is about $5K ($AUD).
    So, here's the real question - how badly do you want to know the answer to your question?
    May 2017
    That was really interesting, thanks for the explanation. I had an accident a couple of months ago, first time I've ever been in a car with airbags going off, made me curious about how it all worked. Never realised the system really thought much beyond a certain level of pressure on a sensor but I had heard people say that if the airbags went off, you're likely to have some level of structural damage - so that makes a little more sense if the control module reads the resonating vibrations.
    2018 Manual Mk 7.5 110TSI Trendline in Atlantic Blue
