Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: 245 instead of 235. whos done it, golf r / cadiz
    Feb 2015
    Sydney, Australia.
    saw this floating around in this forum and now thinking of doing this on 19" cadiz with golf r.. whos done it and how did they find it?
    Feb 2015
    Sydney, Australia.
    anyone?
    Canberra
    Watch out the different profile doesn't rub (IIRC there is a mod to remove the screw that usually rubs). If the rolling diameter is different it may affect the accuracy of your speedo.
    Feb 2015
    Sydney, Australia.
    Quote Originally Posted by gregozedobe View Post
    from what ive read it makes the speedo closer to real speed with 245... just want to see if anyone done this on the golf r ... seen alot for skoda
    What is the reasoning behind wanting 245's? Because 235/35 is a more common tyre size so there will be more brands to choose from and prices will be cheaper.
    Will a 245 fit on the rim? Will a 245 rub on the guards at the front?
    Feb 2015
    Sydney, Australia.
    reasoning is as stated... the speedo on the dash is closer to actual driving speed... slighly more rubber too after having a blow out on the freeway could have a bit more extra meat on the low profile
    Quote Originally Posted by amunra View Post
    The tiny sidewall increase and slight overall rolling diameter increase may be fine or may be just enough to start rubbing on the inner guards etc. I know a lot of people with the GTI's (myself included) go from the factory 225/35 to a 235/35 and they fit fine because the Golf R comes with 235/35's, but cant say ive heard of anyone trying to go to a 245/35 size.
    Is your car lowered or factory height? If you are factory height then you would have a better chance of them fitting without issue. Also, do you have spacers on your factory rims or not?
    Feb 2015
    Sydney, Australia.
    suspension / springs r stock
    If your suspension etc is stock then you have the best chance of having a 245/35 work. But you might still be a guinea pig testing it out.
    Feb 2015
    Sydney, Australia.
    willing to try on the next lot of tyres.. unfortunately already have 1 new 235 on the car and 1 waiting due to 1 newish / middle worn tyre blowing out on the freeway. so next 2 will be 235 aswell.... thinking of getting a spare set of rims and putting 245 on them for extra comfort
