Click HERE to order or for more information.
ECS Performance Intake Systems for your VW MK4 R32 -
The MK4 R32 is especially responsive to airflow modifications because of its naturally aspirated 6-cylinder engine. Small changes in air density can effect huge changes in engine power & smoothness.
Increase air flow rate & density for your VW with the ECS engineered XAS Cold Air Intake System.
The system uses a mandrel bent 70mm (3.0") diameter aluminum pipe, completely replacing the restrictive OE air box and intake snorkel.
