http://www.ecstuning.com/marketing/V...ormance_01.jpg
Printable View
http://www.vwwatercooled.com.au/forums/
Click HERE to order or for more information.
Euro Switch & Fog Light Conversion Kits for your VW MK4 -
Swap wasted space for a brand new face. Install our bumper grille fog light kits in place of those dummy plastic factory grilles. Add great looks and improve lighting at the same time.
These bumper grille kits come with all the good stuff: exact fit grilles with built-in fog light mounts, wiring harness with relay, crimp connectors and twist ties.
Add parking lights with front fogs as well as rear fog options with the easy plug and play euro switch.
http://www.ecstuning.com/marketing/V..._Switch_01.jpg
VW MK4 Golf Wheel Spacers -
Spacers for your racer. ECS Tuning lets you tweak your stance - or swagger down the road with a 20mm monster offset. Engineered and tested in-house to fit your VW perfectly.
Choose from our huge inventory of hub centric spacers in thicknesses sure to match your car, your wheels, and your shopping budget.
All ECS VW spacers are aluminum, and are black anodized for corrosion protection. Kits come with correct-length lug bolts for a complete package.
http://www.ecstuning.com/marketing/V...Spacers_01.jpg
VW MK4 Golf Headlights and Tail Lights -
Nothing improves the appearance of your VW like new headlights and tails.
The front and rear of the Golf centers primarily around it's headlights and tail lights. The good part about this is that you have the ability to easily refresh and update the styling of your car with a simple upgrade.
Whether you want European lighting, projectors, or US Spec Lighting, ECS Tuning has all the bases covered.
These lights will upgrade the look of your vehicle, while keeping it simple and in many cases even improve your nighttime lighting.
http://www.ecstuning.com/marketing/V...TLights_01.jpg
VW MK4 Jetta Headlights and Tail Lights -
The front and rear of the Jetta centers primarily around it's headlights and tail lights. The good part about this is that you have the ability to easily refresh and update the styling of your car with a simple upgrade.
