Click HERE to order or for more information.
VW B5 Passat 1.8T Ignition Service Kits -
The combustion event inside the cylinder must be carefully controlled to realize maximum power and efficiency.
If your old coils are tired and unable to do the job, an ignition service kit from ECS Tuning will put some zap in the gap when you need it most.
Our ignition service kits are easy to install and come with everything you need to restore secondary ignition efficiency to fire at voltage levels adequate to get the most from each and every power stroke.
