Results 1 to 10 of 16
Thread: S3 8L not shifting smoothly at all plus fueling issue...?
    Nov 2014
    I've owned my S3 2002 since June and its been getting progressively worse.
    Going from first to second and second to third the car will kind of shunt into the next gear unless i rev up into the next gear, pull out the clutch extremely slowly or i'm hammering it and shift as quickly as possible(which I don't really want to do)
    I feel that the revs are dying really quickly during gear changes but can't be sure as I've nothing to compare it to and haven't driven an S3 before.
    I've heard the dogbone powerflex upgrade might help but I can't tell. Anyone experienced the same?
    Also should probably mention that the car is using a hell of a lot of fuel and will stutter around 4k when I've got my foot to the floor but only in second and third not in first (haven't tried in 4th or up due to everyones friend the national speed limit)
    this only happens from a standing start as in if i downshift to 2nd and put my foot down it goes with no issues at all but if i go hard through first then into second it occurs.
    Basically just looking for advice or if anyone has experienced the same, should I go ahead and do the dogbone anyway and see how it goes?
    any thoughts on the stuttering?
    Nov 2014
    Are you in Brisbane?
    yeah mate in Brisbane.
    Quote Originally Posted by jgribben View Post
    Can you meet me at the airport one evening, tuesday or wednesday, i'll take a look at it with you. I can bring my S3 and you can compare it.
    Nov 2014
    I'll take you up on that one Gavin is this Tuesday (23rd) too busy with christmas? I'm free all tomorrow.
    No tomorrow is good for me. 1830 at the Maccas near the International terminal. I start at 7 but can be a bit late getting in as I am the gaffer Silver S3.
    Nov 2014
    i should add i've had coil packs replaced
    and taken it to the garage three times and they have said minor boost leak and replaced a hose or two.
    issue is still there
    Nov 2014
    So after meeting Gav at the airport and scanning the car. The EGT sensor kept coming up as a fault. Also he gave me a chance to drive his and now I'm desperate to get mine to stage 2
    Had a good look this morning. Sensor looked fine followed the wire no splitting or anything. Got to the front next to the dipstick took off the black cover and the bloody plug wasn't plugged in. So plugged it it. Warmed the car up put my foot down and everything is fine again.
    So now that it's sorted hoping to get my brakes done next month then get started on some performance stuff.
    100% credit to Gav. Thanks so much for your help otherwise I'd be lost. And thanks for the diagnostic advice which stopped me from spending money on parts that don't need replaced
    Can't go too far wrong with free fixes!! So is it any quicker now?
    Nov 2014
    Ha. Definitly a 6 pack for you next time I see you! Saved me a bunch.
    Yep more linear on the power a little more punch when downshifting but still not overly powerful but that's to be expected when it's stock.
