Page 43 of 44 FirstFirst ... 3341424344 LastLast
Results 421 to 430 of 436
Thread: Audi S3 8P3 CustomCode Stage 2 PSS
  1. #421
    brisbane
    installed rear upper and lower control arms and had it set-up by Ken at accurate suspension. Will need some arch work before I can squeeze on the 265 tyres but I'm getting closer...
    I used this guide for the torque settings which might be useful to others...
    and this one for the rear arb bolts...
    and finally thought I'd post this here as I'll need it to install my harness...
  2. #422
    brisbane
    I tried making my own boost pressure test kit...
    and failed...
  3. #423
    brisbane
    even after the oil cooler upgrade I'm still suffering high temps on the track so I decided to try one of these...
    it was a bit of a pig to install without removing the front of the car but it is possible. I left the plastic on to try and prevent scratching or bending of fins...
    I've heard good things about these radiators so I've got my fingers crossed...
    water meth is on the way too to try and reduce temps even further...
  4. #424
    brisbane
    rear brake calliper bracket adapters worked out nicely...
    before...
    and after...
    and its pretty hard to tell but they fill the rear wheels quite nicely, not even a wheel weight will fit through...
    in comparison to the rs3 stoppers on the front...
  5. #425
    brisbane
  6. #426
    brisbane
    after numerous failed track sessions blowing boost hoses the cars coming good. I managed to get my pb a street sprints a few weeks ago...
    Pb so far at lakeside - YouTube
    then the next session I attended at time attack I managed to break in to the 60's for the first time. high 60's but I'm claiming it...
    cars feeling really strong now and think I can feel the advantage of the extra 10mm tyre width but not sure if I prefer the AR1 to the nexens. I'll wait until the nexen are completely dead and move back to nankang to let the track time do the talking. saying that the nexens are very old now after after so much track time missed...
    I have a few more mods planned for the s3 but as I always say, its the driver mods that need more work. my next goal is get in to the 59's...
  7. #427
    brisbane
    You’d think so with all the cash I’ve spent on it mate…
    I should have listened to you and saved up my coin for something from the stuttgart factory…
    Hope you’re well, I see the squib is still going strong…
  9. #429
    brisbane
    bit disappointed with my last run at lakeside. I felt like I was improving in some sections, definitely staying flatter through the kink and hungry but slower overall. think it was a case of too fast in and slower out...
    only managed a couple of sessions until I started to feel I vibration through the steering wheel. came in to the pits to check wheel studs as it felt like my wheel was going to fall off which is pretty unnerving at 200kph through the kink. I couldn't find anything so back out I went thinking it might be some rubber debris on the tyre. nope, same problem...
    decided I'd swap the wheels in case I dropped a wheel weight which is when I spotted this on the front left...
    pretty certain that's my problem. new tyres need to be ordered. onwards and upwards...
  10. #430
    brisbane
    went to the Noosa Hill Climb...
    got scrutinised...
    turned up to the driver briefing...
    registered a check engine light and loss of power...
    left the Noosa Hill Climb and went back to the hotel...
    tried cleaning the sensor as I found grease on the end...
    cleaning didn't work so i swapped the sensor front rear and the fault followed...
    pleaded Audi Sunshine Coast to open their parts department on a Saturday, thank you guys...
    fixed the fault and went back to the hill...
    couldn't be bothered queuing up in the rain after all that and decided to try again next year...
    hotel was really good for storage so I'll use that again...
    decided to give the car a bath when I got back, it was covered in filth...
    not much fun in the rain but a good group of people...
