Hi,
I just bought an A4 sedan 1.8t manual and ended up also scoring a set of 20 Allroad wheels as well. I need to get some tyres but still havent decided about the size of it.
At first I thought to run 245/30/20 but then after some research found out that the 19 runs on 255/30/19. It made me change my mind about it, then (again) also found out the A5 runs 20 on 265/30/20!
Any one around running 20 to give me some help??? Also, how much pressure are you running on 20?
The Allroad wheels are 8.5 et 43.
Cheers!
PS: I got some H&R on its way too!
A5 will run the following:
245/40R18
255/35R19
265/30R20
RS5 runs 275/30R20. Most will find it cheaper to run 275/30R20 rather than 265/30R20 as the 275 is more common and cheaper. The Speedo will be 0.8% out (speedo 100kmh, actual speed 100.8kmh)
Also the A5 runs a 19x8.5 ET33, 20x9.0 ET?? as per tyre placard.
Tyre pressure for a 265/30R20 on A5/S5 is :
1.8T Front: 250KPa 36psi Rear: 220KPa 32psi
3.0TDI Front: 280KPa 41psi Rear: 220KPa 32psi
3.2FSI Front: 260KPa 38psi Rear: 230KPa 33psi
4.2FSI Front: 280KPa 41psi Rear: 230KPa 33psi
2008 MY09 Ibis White Audi S5 Manual SOLD!
2017 MY18 Manganese Grey VW Passat Alltrack Wolfsburg SOLD!
2018 MY18 Indium Grey VW Golf 110TSI Comfortline, DAP & Infotainment, Folding Mirrors!
2023 MY23 Nevada White Cupra Formentor VZx
