Originally Posted by
its
Hey guys
been reading a lot.. and seems very conflicting readings between choosing VCDS or OBDEleven.. What do you guys recommend?
For OBDEleven AutoInstruct is the one to go for locally I guess for $99 with Pro Version and delivery
Ross Tech HEX-V2 is the one for VCDS (About $368 AUD Delivered)?
https://store.ross-tech.com/shop/vchv2_ent/
Any cheap local / online sellers for that? or some other model of Ross Tech?
Basically trying to figure out what is better to get? huge difference between the two... Can see a lot of tweaks online for VCDS cables but I understand you can do the same with OBDEleven but not straight forward
its: If I may add to Adam's excellent advice - it's ostensibly a "value" decision IMHO.
Basically, it's a matter of making a decision about what aspect of these diagnostic devices that you value most (based on your understanding of your present needs - so there also an element of judgement regarding what your needs will be in the medium to long term)
As Adam says - there is absolutely no doubt that Ross Tech's product is the industry standard - and it has been the industry standard for some time. This is a professional tool, but don't let that label sway your decision - Uwe Ross has indicated that more of his sales are from enthusiasts (like you, and me), than from commercial workshops. But it's not inexpensive (albeit IMO, it's worth the extra expense) - so if you choose a VCDS product, you will be investing in a very, very good piece-of-kit! I've got both the older style HEX+CAN (not available now) and the newest HEX-NET and they both operate flawlessly (the HEX-NET speed is fantastic - it runs like a cut cat!). You can buy HEX -V2 as well which is basically the HEX-NET architecture without cable-less function (HEX-NET can use a WIFI link) and some other smarts - a good alternate for reducing cost. You can also buy unlimited VIN, or limited VIN versions of the HEX series cables to suit your future needs (and you can change these limitations later).
OBD11 is an entirely different way of using a diagnostic cable! Whereas the VCDS software has the complete database for your car's CAN network resident on your laptop - OBD11 downloads this database from a central website based on what the dongle reports about your car. This means that you MUST have a good ISP connection at the point of use - and the speed of this connection determines the quality of the experience! OBD11 also uses bluetooth, so there is a pairing process when first using the product. Another limitation of OBD11 is that it currently ONLY works on Android devices (which aren't expensive to buy- if you don't own a Tablet/mobile phone). BUT - OBD11 is a very inexpensive tool - even if you need to buy a new tablet/mobile phone. I've had an OBD11 dongle for some time and it's also quite good. It does stuff differently to VCDS (some better, some worse) and it also has one-click Apps which implement tweaks easily for new users - these cost "credits". Almost ALL VCDS instructions can be translated into OBD11 speak -so it's newer structure isn't a problem.
So- I guess that my suggestion would be to think about how you might use a diagnostic cable (both now and into the immediate future). If you are the type of person that might get-hooked onto CAN network stuff (as am I), then my advice is to take-the-plunge and invest in a HEX-V2 with limited VIN (you can update this later - if you need more VINs).
On the other hand, if you just want to dabble - then go the OBD11 route initially. Consider the additional cost if you eventually buy a VCDS tool as a training expense, but make sure that you have a good internet connection in your garage/workshop.
BUT - REGARDLESS OF WHAT DEVICE YOU BUY - DON'T UNDER ANY CIRCUMSTANCE BUY A CLONE DEVICE. Those that do purchase fake cables are as complicit in IP theft as are the sellers of these devices!
PS: I see that you live in Melbourne - if you want to see both devices in action , PM and we can arrange an introductory training class (I seem to do many of these -these days). I can sit you in front of my CAN-BUS test-bench. It's my "virtual" car - a type of "simulator" (see picture below). You can try both devices and you can attempt to make whatever changes that you like - without the fear of breaking anything .
