Page 41 of 46 FirstFirst ... 313940414243 ... LastLast
Results 401 to 410 of 452
Thread: VAG-COM scanning, who can help
  1. #401
    May 2014
    Gold Coast, QLD
    Is anyone available on the Gold Coast to code a highline RVC (swivelling lines) to a RNS315 in a 2014 Amarok Highline?
  2. #402
    May 2014
    Gold Coast, QLD
    Quote Originally Posted by mrst3ve View Post
    bump, happy to pay... closest i’ve got is $198 on the Sunshine Coast
  3. #403
    Dec 2006
    Kilsyth, VIC
    Did you install the headunit or the RVC?
  4. #404
    May 2014
    Gold Coast, QLD
    Quote Originally Posted by The_Hawk View Post
    The headunit already was in the Amarok. I installed the RVC.
  5. #405
    Dec 2006
    Kilsyth, VIC
    It’s been a while, but from memory you won’t get bendy lines since there’s a part in the steering wheel you need too, it also can’t be calibrated outside the factory. I’m questioning that memory a little and maybe they do still turn, but I’m about 80% they don’t.
    At the very least you can turn it on and make it work as a RVC.
  6. #406
    May 2014
    Gold Coast, QLD
    I installed this from Euro Car Upgrades - Volkswagen Amarok Ultimate High Line Reversing Camera retrofit VW OEM 2H0907441 2H0980551 - Euro Car Performance & Electronics Upgrades - so should be good to go. I’ll update once it’s coded, no takers yet though.
  7. #407
    Dec 2006
    Kilsyth, VIC
    My memory is clearly failing me... a quick google turned up my own thread here:
    Rearview Camera install (highline)
    Yes the lines turned in my install so ignore my previous comments and good luck finding someone local to lend a hand getting it coded. Assuming it all works as it should, it's a very quick job.
  8. #408
    May 2018
    Anyone local to Brisbane able to scan my car with VCDS? Got a few codes I need to work out.
    01044 - Control Module Incorrectly Coded
    01276 - ABS Hydraulic Pump -V64 Malfunction
    01130 - ABS Operation Not a plausible signal
    Chris
  9. #409
    Jun 2011
    Bendigo, Victoria
    Anyone got a cable in Melbourne. I had some coding done by EAP eurodiag in the past to code my door light. However James doesnt seems to be doing it anymore. One of my Mk6 Wagon doors lights has stopped working.
  10. #410
    Just bought a new Varta battery (AGM) for my 2014 MK7 Golf GTI and unfortunately discovered my (not cheap) BlueDriver OBDII scan tool doesn't support battery registration for VW yet
    Anybody in Melbourne with a cable willing to give me a hand with this?
    Thanks in advance
    2014 GTI | Pure White | Manual | Sunroof | DAP | Dog sleeping on back seat |
