Results 1 to 6 of 6
Thread: Vag Com not working since upgrade to Win 10 (not sure why)
The Last Streetfighter Vag Com not working since... 26-04-2016, 07:55 PM
Greg Roles Windows 10 also makes... 27-04-2016, 07:01 AM
mr gee mine works in Windows 10.... 27-04-2016, 06:32 PM
Idle Yes, try a re-install. It... 28-04-2016, 10:48 AM
DV52 hmm........ What version of... 28-04-2016, 06:44 PM
Peteintas It's most likely a Win 10... 14-05-2016, 12:09 PM
    Hi Guys
    I'm trying Vag Com for the first time since upgrading and it just stops working and windows doesn't seem to know why.
    Any tips? Same old B5 Passat
    Trev
    Jan 2008
    Sunshine Coast
    Windows 10 also makes handheld tune loaders play up, so I'd say Vag Com is not yet compatible, best ask Ross Tech.
    Windows 10 sucks.
    2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
    Mar 2009
    Melb
    mine works in Windows 10. what you can try is reinstall the VCDS software
    Tig 162 R-Line; Audi TT
    Dec 2009
    Kew, VIC
    Yes, try a re-install. It works on my laptop with 10.
    hmm........ What version of VCDS cable do you have? Like Ops above, I've been using my HEX+CAN with previous version SW successfully on Window 10 for quite a while (64 Bit operating system).
    I also recently upgraded to the latest version software (Beta 16.3.1.1) - re-flashed the firmware in the cable and not a problem using windows 10.
    Have you pressed the "save" button after testing the USB port - after using the newly loaded software for the first-time?
    Jan 2013
    Hobart Tasmania
    It's most likely a Win 10 issue with your PC, release version & current beta certified & working correctly on Windows 10.
    My16 Golf Alltrack, DAP
    MY18 Golf Comfortline
