Results 1 to 7 of 7
Thread: OBDeleven blocked
    Dec 2015
    NSW
    OBDeleven blocked
    Santa gave a friend of mine an OBDeleven dongle for Xmas.
    How does s/he (the friend) download the softwares ?
    All I can find is this message on the Voltas IT website.
    Voltas IT Support
    Sep 2012
    Once you get the software, the security settings on the phone/tablet need to be changed to allow an install from unknown sources. If you have any trouble getting the software let me know - I can dropbox it.
    Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
    Jan 2014
    Queensland
    Open on your android device and allow to install from unknown source App
    Dec 2015
    NSW
    I just updated my obdeleven software after a long time of not being used.
    Made some notes to help next time/s. Hope these short notes help others too.
    There's sure to be a way to adapt this for Windoze and/or OSX.
    Using a Linux host, download the latest apk from
    https://obdeleven.com/application/OBDeleven.apk
    Must have package android-tools installed (RHEL, CentOS, etc)
    Enable the Android (eg OnePlus) device in following file on Linux host :
    /etc/udev/rules.d/51-android-rules
    use dmesg for the vendor and device ID's
    Example usb 2-1.1: New USB device found, idVendor=2a70, idProduct=f003
    Setup the adb connector on Linux host
    /root/.android/adb_usb.ini
    eg 0x2a70 as above
    Connect the phone using usb cable
    Enable usb debugging in Settings, System, Developer options
    uninstall the old obdeleven version from the phone, else the install below will fail
    From the Linux host
    # adb kill-server
    # adb start-server
    # adb devices -l (lowercase L, not numeric one)
    Make sure phone is listed
    Then
    # adb install OBDeleven.apk
    Wait while approx 25MB are transferred to phone.
    "Success" message when complete.
    Turn off usb debugging if desired.
    Current : 2017 Mk7 Golf R (most options) || 2012 Golf Mk6 TDi (few options)
    Gone : 2004 Bora V6 4Motion (few klms, all options)
    Pacific Paradise QLD
    No need to do that any more at all and I never did all that in March when I got mine Simply typed the addy into the phone and it downloaded the APK
    HOWEVER as OBD ELEVEN is now legally licenced to use world wide except for China it is a simple download from the Playstore
    But as said you must allow other apps
    Have just installed it on a spare phone took about a minute and all working
    Dec 2015
    NSW
    Mine wouldn't update via the Play store, so I used the legacy method above. It still works.
    Quote Originally Posted by bgroper View Post
    Have you got unknown apps allowed as i used an old phone and its fine also on my S6
