ECU swap 125kw Passat 08 model
Any one familiar with swapping a second hand ECU into the above? Have checked some re programming stuff on u tube and came across one which said if u swap the EEPROM from old to new ECU via de soldering and re soldering then re coding is not necessary, the Ecu was a edp15 Bosch model and mine is a Siemens model so was wondering if this can be done given the EEPROM stores immobiliser coding according to the video. Any info regards this appreciated cheers RON.
- You may not post replies
- You may not edit your posts
Forum Rules
