Results 1 to 3 of 3
Thread: Last 2 errors - can someone help me
    Oct 2010
    Perth, WA
    Hi Guys
    I have upgraded my CAN Gateway for my RCD510 install and I have two errors that I cannot get rid of, maybe someone can help?
    Wednesday,31,July,2013,20:08:55:60875
    VCDS Version: Release 11.11.6 (x64)
    Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
    Control Module Part Number: 1K0 959 433 BL
    Component and/or Version: 01 KSG 0301
    Software Coding: 91C802087F2D8505485FC69010
    Work Shop Code: WSC 50620 812 60948
    Additional Info: 1K0951605C LIN BACKUP HORN H03 1301 1K0907719B Neigungssensor 004 0003
    Additional Info: 1K0951177 Innenraumueberw.004 0101
    VCID: 7BDB2A1C3A08ABC0759
    1 Fault Found:
    01134 - Alarm Horn (H12)
    004 - No Signal/Communication
    Wednesday,31,July,2013,20:06:24:60875
    Address 61: Battery Regul. Labels: 1K0-907-534.clb
    Control Module Part Number: 7N0 907 534 HW: 7N0 907 530 G
    Component and/or Version: Batt.regelung H41 1632
    Software Coding: F000185A
    Work Shop Code: WSC 12345 123 12345
    VCID: F1C78834284451905F5
    1 Fault Found:
    02071 - Local Databus
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 0
    Mileage: 71621 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 20:59:03
    Adelaide hills, SA
    Where are the car details? Model? Year?
    If you don't have the back up horn and the stop start system, then you can just disregard these faults.
    Dec 2008
    Sydney/Canberra
    Like I said the other day, either code them out, or ignore them.
    The codes basically translate to not being able to communicate with control modules that aren't fitted.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
