Results 1 to 8 of 8
Thread: MFD Bluetooth menu not working with RCD-510 + 9W7 + Polar-Fis-Advanced PF03
    Mar 2010
    Forest Lake, QLD
    Hello.
    I have recently installed a RCD-510 and 9W7 bluethooth kit in a 2008 MKV Gti with an existing PF03 and stock can-gateway.
    Everything is working as expected on the Radio side of things, including bluetooth, microphone etc..
    However, I can not access the MFD bluetooth menu.
    I figured this was something to do with VCDS coding. I have a vagcom cable and currently there are no faults.
    Any advice would be very much appreciated.
    Cheers,
    James
    You need to add telephone (address 77) to the list of installed modules in the canbus gateway (address 19).
    Mar 2010
    Forest Lake, QLD
    Yes telephone 77 is in the list of installed modules and is selected. I can navigate this module ok, and it shows no faults.
    Might be helpful to post the autoscan
    Mar 2010
    Forest Lake, QLD
    Saturday,02,September,2017,15:03:57:33552
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 17.8.0.1 (x64)
    Data version: 20170721 DS276.2
    Ross-Tech: Home
    VIN: WVWZZZ1KZ8U005320 License Plate:
    Mileage: 257020km-159704mi Repair Order:
    Chassis Type: 1K-VW35 (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 75 77
    VIN: WVWZZZ1KZ8U005320 Mileage: 257020km-159704miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    75-Telematics -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels:. 06F-907-115-AXX.clb
    Part No SW: 1K0 907 115 Q HW: 8P0 907 115 B
    Component: 2.0l R4/4V TFSI 0010
    Revision: 5BH16--- Serial number: VWX7Z0G63N58GO
    Coding: 040300431C070160
    Shop #: WSC 14645 025 402983
    VCID: 346D270B57B87FE65E-8060
    No fault code found.
    Readiness: 0000 0001
    Address 02: Auto Trans Labels: 02E-927-770.clb
    Part No SW: 02E 300 044 J HW: 02E 927 770 AE
    Component: GSG DSG 081 1407
    Revision: 00008010 Serial number: 00000706181518
    Coding: 0000020
    Shop #: WSC 44551 111 44551
    VCID: 1C3DEFABDF28D7A676-8048
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0004738
    Shop #: WSC 00046 412 00000
    VCID: 73EFE417123638DE87-8026
    Address 08: Auto HVAC Labels: 1K0-907-044.lbl
    Part No SW: 1K0 907 044 BR HW: 1K0 907 044 BR
    Component: ClimatronicPQ35 120 1111
    Revision: 00120021 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 78F5D33B0B505B86B2-802C
    Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
    Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
    Component: Bordnetz-SG H54 2202
    Revision: 00H54000 Serial number: 00000007164270
    Coding: E58D0D2700041500471400001400000000087F075C00010000 0000000000
    VCID: 71E3EE1F682A0ACE75-8024
    Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer 220807 020 0501
    Coding: 00049109
    Shop #: WSC 00046
    Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
    Component: RLS 040707 046 0204
    Coding: 00208933
    Shop #: WSC 00046
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: 1P AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 0038PD19P4KM
    Coding: 0012624
    VCID: 3D7B022F64F2BEAEA1-8068
    Subsystem 1 - Serial number: 6332MSME16206600Z
    Subsystem 2 - Serial number: 6342MSME19491077A
    Subsystem 3 - Serial number: 6352QSME2D2C2E67Z
    Subsystem 4 - Serial number: 6362QSME2E0E3F21T
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
    Component: J0527 636 0070
    Coding: 0012122
    VCID: 0103BEDF588A1A4E85-8054
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 002 0010
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No SW: 1K6 920 874 HW: 1K6 920 874
    Component: KOMBIINSTRUMENT VDD 1216
    Revision: V0002000 Serial number: VWX7Z0G63N58GO
    Coding: 0003103
    Shop #: WSC 20048 959 69581
    VCID: 70E5EB1B632003C67A-8024
    Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
    Part No SW: 1K0 907 530 L HW: 1K0 907 951
    Component: J533 Gateway H07 0052
    Revision: H07 01 Serial number: 300507F1000542
    Coding: ED807F063006020003
    Shop #: WSC 00046 412 12345
    VCID: 30652B1BA3A043C63A-8064
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO VDD 1216
    Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
    Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
    Component: Tuer-SG 006 120B
    Coding: 0000692
    VCID: 3875133B4BD09B8672-806C
    Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
    Part No: 1K2 909 144 M
    Component: EPS_ZFLS Kl.069 H08 1901
    VCID: 36691D0341C46DF660-8062
    Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
    Component: KSG PQ35 G2 020 0203
    Revision: 00020000 Serial number: 00000000000000
    Coding: 819002005103087F2D04840570085FC690FC00
    VCID: 030FB4D74296085E97-8056
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 1K0 951 178 A
    Component: Neigungssensor 003 0203
    Subsystem 3 - Part No: 1K0 951 178 A
    Component: Innenraumueberw.003 0203
    Address 47: Sound System Labels: 3C0-035-456.clb
    Part No: 1K6 035 456 A
    Component: 08K Audioverst. 0005
    Revision: 00003000 Serial number: 00000000139292
    VCID: 2A513973857C3916F4-807E
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
    Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
    Coding: 0000692
    VCID: 3973163F70DA828E8D-806C
    Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
    Part No SW: 5K0 035 190 A HW: 5K0 035 190 A
    Component: Radio RCD510 050 0207
    Revision: 00000001 Serial number: VWZ1Z3L1586948
    Coding: 01000000010005
    Shop #: WSC 01357 011 00200
    VCID: 234FD4572256E85EB7-8076
    Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
    Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
    Component: Tuer-SG 006 1201
    Coding: 0000144
    Shop #: WSC 00046 412 1012544
    Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
    Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
    Coding: 0000144
    Address 75: Telematics
    Cannot be reached
    Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
    Part No SW: 7P6 035 730 P HW: 7P6 035 730 P
    Component: TELEFON H15 4217
    Revision: 1B001001 Serial number: 00007665756135
    Coding: 0A00000000010110
    ASAM Dataset: EV_UHVNA 002720
    ROD: EV_UHVNA_002.rod
    VCID: 3F877827A6FEACBEB3-806A
    End-------------------------(Elapsed Time: 02:03)--------------------------
    Looks OK, might be something that needs to be tweaked in the Polar FIS settings?
    I'm not familiar with the ins and outs of the PS03 as I've never owned one so can't offer much guidance there sorry.
    Mar 2010
    Forest Lake, QLD
    Thanks. I have contacted AutoPolar to see if there are any issues with the PF03 and this setup. I will post back the details.
    It's the polar fis that does the translation from BAP to DDP so if it's not working correctly your instrument cluster won't know what to do with commands from the BT module.
