Results 1 to 5 of 5
Thread: Vcds or obdeleven in brisbane
    Jun 2022
    acacia ridge queensland
    Hi all
    Just looking for someone with vcds or obdeleven around Brisbane who will rent or will help with some programming in my vw up.
    I need to do a bcm swap for a cruise control retrofit.
    Pacific Paradise QLD
    Quote Originally Posted by kristianvanek View Post
    Hi all
    Eurocarupgrades will do that but are $180 an hour
    Nov 2007
    PM, me I can help with VCDS. Just need to research what you need coded as I haven't done a BCM swap on the Up! before.
    Jun 2022
    Just sent you a message.
    Jun 2022
    Mooloolaba isn't really brisbane
    I want to just plug a bcm in and change 1 setting to see if what I was told works. Easy 5 min job for obdeleven or vcds that some one with at home would take a 6pack or a few dollars to do it. For 180 an hour I would just spend the extra few dollars and buy a obdeleven.
