Page 5 of 5 FirstFirst ... 345
Results 41 to 47 of 47
Thread: Engine check light
  1. #41
    May 2013
    Qld
    Is the bad fuel their excuse to attempt to make you pay for the injectors under warranty.
    Dealership scanned the engine light which was logged as a misfire but apparently they cant tell which cylinder it was?
    Cars due for 60k service in bit over a 1000km so apparently no point playing with sparkplugs/compression testing now.
    Heres a few year old video of the car sounding like a trabant
    https://youtu.be/RS-1uAagzUk
  2. #42
    Dec 2007
    ivanhoe vic
    That is ridiculous good luck
    B6 Passat Wagon No KESSY
  3. #43
    Aug 2012
    The strict advice I had from VW/Skoda Australia is that the car was not to be driven if the ECM light came on. They said : call the tow truck.
    If you have an ECM issue, they must check compression - if they'd pulled the head on mine earlier, I probably would not have blown a piston...
    Difinity
  4. #44
    May 2013
    Qld
    The book says you can drive on yellow light
    Sent from my LG-H815 using Tapatalk
  5. #45
    Aug 2012
    The advice in mine was to turn the car off and call Skoda Roadside Assist.
    Yours does sound broken though...
    Difinity
  6. #46
    May 2013
    Qld
    That video was from july 2013 car had between 5-10k on the odo back then
  7. #47
    Aug 2012
    Wow
    Difinity
